CEL
Old Jun 2, 2010 | 03:16 PM
perfecteverytime's Avatar
Default CEL
Hello all,
I have a check engine light in my accord. It's a 95 EX 5 speed, with a recent transmission swap. I jumped the two pin connector under the glove box, and watched the CEL flash. It showed one long flash (about 2 seconds) followed by 7 short flashes. What is this a code for.
Thank You,
Chris
Old Jun 2, 2010 | 03:28 PM
poorman212's Avatar
Default Re: CEL
I believe this is the VSS. Was the "swap" to the same type..ie a manual for a manual.
Old Jun 2, 2010 | 03:44 PM
Default Re: CEL
Swap was auto-to-manual. I was thinking VSS too because my speedo crapped out on me the other day. What do I do for the VSS? Is it a small part I can replace myself and pick up from honda?
Old Jun 4, 2010 | 03:53 PM
poorman212's Avatar
Default Re: CEL
If you're sure it's the vss then you can try the dealer if you wish or you can get one from the aftermarket. Dorman Products offers one # 911-751. You can go to thier website and look it up and get a picture of it.
Old Jun 4, 2010 | 03:58 PM
Default Re: CEL
I still have the VSS that was from my auto tranny. Does the manual transmission require a different VSS? If not, I could use the one from the Auto tranny, which I know does work.
Old Jun 4, 2010 | 04:07 PM
poorman212's Avatar
Default Re: CEL
According to a couple of sites (Dorman Products, Worldpac) I looked at it does not matter.
Old Jun 5, 2010 | 02:17 PM
Default Re: CEL
I installed the VSS from the auto tranny, and it worked fine. No CEL and and my speedo works! Thank you for the info!
Biggem Clark
Aug 8, 2016 07:17 PM
Addicted2Vtec
Dec 17, 2009 03:54 AM
Carson89X
Feb 18, 2005 09:06 AM
D_TY3
Dec 12, 2003 04:43 AM
