EF Coilovers -- Please help guys!
Old Sep 12, 2002 | 11:56 PM
B16A1-EF9's Avatar
Default EF Coilovers -- Please help guys!
So here we go. I bought this set of Weitec coilovers for my car. They don't make an EF kit only an EG and up kit. The problem I'm having is that the car is higher then with the stock suspension and the coilover is all the way down. I had to change the suspension forks because the EG shocks are thicker then the EF's so I bought 90-93 Accord forks. Anyway...what is causing the car to be so high?
What can I do to fix this problem?
Old Sep 13, 2002 | 05:03 PM
B16A1-EF9's Avatar
Default Re: EF Coilovers -- Please help guys! (B16A1 - EF9)
Figured it out finally.
What I did was put the rear springs on the front shock and the front springs on the rear shock. Since the spring rate on the rear is different then the fronts it lowered it a bit. Then I removed the helper springs. I also got EG 92-95 front forks and it solved all my problems. The car is really low now. I'm going to leave it the way it is until it settles and then I'll adjust for best corner weight.
Linville33
Oct 10, 2014 07:05 AM
bmxtrev
Suspension & Brakes
20
Dec 29, 2011 02:47 PM
Type-R32
Oct 5, 2008 07:23 PM
B16A1-EF9
Sep 13, 2002 07:31 PM
B16A1-EF9
Sep 13, 2002 05:01 PM
