EF Coilovers -- Please help guys!
Old Sep 12, 2002 | 11:54 PM
B16A1-EF9's Avatar
Default EF Coilovers -- Please help guys!
So here we go. I bought this set of Weitec coilovers for my car. They don't make an EF kit only an EG and up kit. The problem I'm having is that the car is higher then with the stock suspension and the coilover is all the way down. I had to change the suspension forks because the EG shocks are thicker then the EF's so I bought 90-93 Accord forks. Anyway...what is causing the car to be so high?
What can I do to fix this problem?
Old Sep 13, 2002 | 03:37 AM
keithv's Avatar
Default Re: EF Coilovers -- Please help guys! (B16A1 - EF9)
here are a few thoughts i had after reading your post.
1. did you install the threaded sleeve upside down?
2. do you have the front sleeves in the rear and the rear sleeve in the front?
3. how long are the springs that came with the coilovers?
Old Sep 13, 2002 | 04:35 AM
E-AT_me's Avatar
Default Re: EF Coilovers -- Please help guys! (breaka_1_9)
people have told you this before!! EG stuff is longer than EF!!
Old Sep 13, 2002 | 08:39 AM
B16A1-EF9's Avatar
Sleeves??? These are not Ractive coilovers man. They are true racing coilovers.
Http://www.weitec.com look-up Hicon TX coil-overs. There is no sleeve to install.
The spring rates I don't see being much higher then the EF's since the cars son't weigh that much more. The springs do look longer though.
Old Sep 13, 2002 | 05:01 PM
B16A1-EF9's Avatar
Figured it out finally.
What I did was put the rear springs on the front shock and the front springs on the rear shock. Since the spring rate on the rear is different then the fronts it lowered it a bit. Then I removed the helper springs. I also got EG 92-95 front forks and it solved all my problems. The car is really low now. I'm going to leave it the way it is until it settles and then I'll adjust for best corner weight.
Pat92904
Suspension & Brakes
11
Oct 28, 2016 11:50 AM
thedudefromjerz
32
Oct 27, 2006 05:01 PM
B16A1-EF9
Sep 13, 2002 07:31 PM
B16A1-EF9
Sep 13, 2002 05:03 PM
