H22 custom header testing
Old Jun 2, 2010 | 08:06 AM
h23V's Avatar
Default H22 custom header testing
Just making a thread from the bisi header group buy as i don't think bisi is gonna send a header or really have much to say but just i'm a engineer.
Old Jun 2, 2010 | 08:08 AM
h23V's Avatar
Default Re: H22 custom header testing
NAH2B This question is for u
So how far are u on finishing the new header and testing the new bigger tube primary. And also since u have skunk2 as a sponsor have u ever tested the pro2's in ur setup just to make a comparison and track test and dyno it to see the gains u may be able to make more cam gear adjustments with a camshaft with lower lift.
I see there is a big difference between the pro2's and pro3's as far as the opening peak and closing event's by 4-6 degrees maybe u can shift ur power band using the lower lift cams by using that advantage. Also seeing if u have already done this also.
I know it's kinda getting off the subject but love trying to give my .02 cents to help someone into better et's more mph.
Old Jun 2, 2010 | 05:41 PM
NAH2B's Avatar
nope didnt test the pro 2s, gonna stick w/ the 3s.
im still trying to decide if im gonna do a side exit or another under the pan header, so i havent started on it yet other than opening up the flange for 1 7/8" tube.
im planning on getting it done sometime this month so i can hit the dyno and test a few headers before the IFO race on June 11th. theres just not enough time to do it before the june 13th race next weekend.
when i get close i will let everyone know and they can send me some headers to test. if you guys are gonna send me anything w/ 1 3/4" coming out of the head make sure to grind it open as much as you can...
Old Jun 2, 2010 | 07:04 PM
h23V's Avatar
So y not test the pro 2's just like u would test a smaller header like the kidd racing header that's not built for the engine. I mean i would dyno and track test just to say that u can rule out that the pro 3's are the perfect match for ur setup u might be surprised.
Like with my custom ported intake manifold that i have i'd love to test it against a skunk2 or euro intake manifold to see if i made a good design or if it works for my setup which i'll be doing soon a buddy of mine has one.
Old Jun 3, 2010 | 12:39 PM
smlblkpro's Avatar
you ready for oil
Old Jun 3, 2010 | 02:59 PM
NAH2B's Avatar
the pro 2s dont fit my build, they are to small and will make less power so i have no interest in testing them...
h23vtecpowered
Nov 5, 2008 02:52 PM
A Blue Lude
16
Nov 11, 2005 08:33 PM
jdmcivicferio
Jul 3, 2004 04:05 AM
ranta18
Oct 7, 2003 09:14 AM
