Skunk2 Pro2 H22A Cam Facts urgent needed!!
i need some (all) facts from the H22A Pro2 cams please.
what i need is exactly the valve chart from the cams.
we will calculate the engine (runners lenght, runner diameter, header, .....)
i hope anyone have that for me ?
thanks!
thanks!
All specs are measured with 0 valve lash. Checking point for duration, opening and closing figures is 1mm lift (.039"). All specs are for Vtec lobes.
Pro Stage 2 Camshafts
Intake: 12.5mm max lift. 265° duration. Opening 35° ATDC Closing 50° ABDC
Exhaust: 11.6mm max lift. 272° duration. Opening 53° BBDC Closing 39° ATDC
We recommend setting the centerline for the Intake cam to between 99° - 100° ATDC
We recommend setting the centerline for the Exhaust cam to between 104° - 105° BTDC
If you need any more information email BrianN@Skunk2.com and I will get you anything you need.
Jan 27, 2021 12:44 PM
