front sway bar on eg
Old Sep 12, 2002 | 10:32 PM
speshuled619's Avatar
Default front sway bar on eg
what is needed to use a gsr front sway bar on an eg? i would like to upgrade my stock one. and is it as simple as just swaping the old one out and sticking the new one on?
Old Sep 12, 2002 | 11:04 PM
J.P. 4rm The dPk*'s Avatar
Default Re: front sway bar on eg (speshuled619)
Drilling is involved. After that ur home free.
Old Sep 12, 2002 | 11:39 PM
From: LA, Hawthorne, Alhambra, Monteghetto, CA, USA
Default Re: front sway bar on eg (Spooner)
if you have an Si. there is NO drilling involved. everything is bolt on.
Old Sep 13, 2002 | 04:42 AM
shawnhayes's Avatar
If you have a stock one from an EG, the new one bolts right up. However, I wouldn't recommend "upgrading" the front sway bar. The already bad understeer in an EG will only be made worse by upgrading the front bar. Upgrade the REAR bar first.
Shawn
roycivic92
Suspension & Brakes
May 22, 2010 09:04 PM
E36 Guy
Nov 2, 2005 06:55 PM
SuicideSlide
Apr 10, 2005 10:47 AM
hype r 555
Aug 10, 2004 10:46 AM
