Need help guys. This is an EMERGENCY
OK I was trying to tighten the alternator belt with the tire iron and it touched the wire going to the alternator and grounded on the block. A huge spark came from it and now noting turns on. NOTHING! No lights and the car won't start. It' won't even try at all. What could have happened? I checked the alternator relay fuse and it's okay. Is there another fuse I need to check? Any help is appreciated. Thanks in advance
I did almost the same thing on a celica once... the owner set the battery in backwards, so the poles were reversed. When I went to lock down the battery cables, it arced huge, and nothing came on.
The answer... The 100A alternator fuse blew, as well as a couple others. (ECU, Main Dist., etc.)
You shouldn't have done any damage to anything else. Get a FLuke and start checking circuits if that doesn't solve it.
Good luck
Good luck
chadmasterc
Jul 29, 2003 02:11 PM
