Suspension & Brakes Theory, alignment, spring rates....
Wheel Bearing gone bad?
Old Jun 1, 2010 | 05:21 PM
chanelton's Avatar
Default Wheel Bearing gone bad?
getting a knocking/thumping noise which leads me to believe it is my wheel bearing but when I either turn left or right, the noise remains constant. noise gets faster as I accel. The weirdest thing though is that when I engage the brake, the noise stops completely, as soon as I come off the brake the noise comes back. Could it be the wheel bearing?
2003 Honda Civic SIR EP3
112000 kms
Old Jun 2, 2010 | 04:07 AM
richi86's Avatar
Post Re: Wheel Bearing gone bad?
on witch ever wheel it is that's making that noise i would check the caliper and make sure its on there right make sure that the bolts are in there right and your not missing any ..make sure ur breaks look good, there is little clips the pads sit on check those too if it was a wheel bearing then it would still make the noise if u hit the break.
Old Jun 4, 2010 | 11:06 AM
D_Uniteer's Avatar
Default Re: Wheel Bearing gone bad?
the same thing is happening to my 2003 si as well.... anybody know the problem!
Old Jun 4, 2010 | 11:50 AM
phunhaus's Avatar
If it's not a rotational noise you can pretty much eliminate the wheel bearing.
The EM2/EP3's are known to have bad front LCA bushings. See if yours are in good shape or torn. This is the front lower arm where the bushing center goes vertical as opposed to horizontal. It's number 11 in this picture:
http://www.hondaautomotiveparts.com/...tcgry5=KNUCKLE
Tigereye225
Honda Civic (2001 - 2005)
May 15, 2016 03:59 PM
91EF_Si
11
Mar 13, 2008 03:45 AM
Mr.Luder
Oct 16, 2007 03:54 PM
schpiel
Sep 17, 2007 07:28 PM
coot_er
Mar 29, 2005 03:47 AM
