need welder in socal, weld turbo exhaust housing
Old Jun 1, 2010 | 05:04 PM
drift2004's Avatar
Default need welder in socal, weld turbo exhaust housing
i could weld a flange for a regular 4 bolt downpipe, but i will have limited access to one of the bolts. i need someone to properly heat up the cast iron turbo exhaust housing and weld it to a small section appx 2-3 inches of stainless steel( 3inch in diameter) at a 45degree angle to be welded on to the turbine housing with a 4 bolt housing. a quote also for v band. here an example of how i needed welded withoutthe flange. and to whoever welded to provide materials, unless i need to buy it.
here the example
contact jason or text 323-712-0592
93c1sol
Welding / Fabrication
Aug 28, 2007 06:17 AM
95GSRTT
Mar 31, 2007 11:03 PM
2muchPSI
Mar 5, 2006 11:33 AM
JD95hatch
Oct 14, 2004 01:23 PM
raceteamintegra86
Jul 21, 2004 05:29 PM
