my old school gsr build
Old Jun 1, 2010 | 03:31 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default my old school gsr build
Iv been looking for a new bottom end for my sedan and ran into this on ebay, Im hoping it will work ok with my b16 head and blox B cams
http://cgi.ebay.com/ebaymotors/ws/eB...AQ:MOTORS:1123
from the zeal comp calculator it says the motor should be around 11.5 to 1 comp with a oem headgasket and un milled head. I have a feeling it will be a little bit higher then that though.
should I need to worry about p2v clearance with blox B cams? (s2s2 knock offs) running stock sized valves.
any insight on expected power?
00 b16 head
blox b cams
blox dual v.s.
itr retainers
1st gen skunk2 i.m.
bbk70mm t.b.
3" short ram with V stack
b17a1 bottom end, arp rod bolts, ctr pistons oem everything
ebay 4-1 header with 2.5" collector mod.
Id be happy with 180-190whp if that is achievable I know a better header would def help but not sure on what header would suit this motors needs, I may have a JG header lined up though as soon as my buddy goes to turbo.
Old Jun 2, 2010 | 12:23 AM
Loved
Community Favorite
Default Re: my old school gsr build
with the pr3 head, b17 bottom end and ctr's this should be a 12.2 to 1 motor according to the huge ctr comp thread. I think that will be perfect with the blox B cams and shouldn't any det. problems due to to high of dynamic compression ratio. only thing Im worried about is p2v clearance but Im pretty sure I won't have any issues.
what would be a good header for this setup?
I kinda wanna do a header test on it with a few different ones to see what will work the best, probably mainly cheap headers (ebay, used dc, possibly a JG) all with modded 2.5" collectors.
heres the current b16 in the car, smokes hella bad but seems to run pretty damn good
bpoweredeg6
15
Sep 1, 2013 05:48 PM
built95gsr
Jun 26, 2007 10:37 AM
civicandy
34
Nov 21, 2006 10:56 AM
b18jdmteg
Sep 26, 2006 06:34 AM
tnsxsear1
11
Mar 27, 2004 03:13 PM
