Suspension & Brakes Theory, alignment, spring rates....
Rack n pinion question
Old Jun 1, 2010 | 03:30 PM
092eg6's Avatar
Default Rack n pinion question
hello i have a 93 honda civic CX with a GSR and evrytime when i go over 75mph the steering wheel starts to vibrate and shake alot and it seems like it vibrates from the wheels to the sterring wheels. I have done about everything i can think off to fix the problem but it has not done anything to it.
So far this is what i have done:
Bought new tires, mount and balanced
replace new motor mounts
alignment
replace new brakes and rotors
replace new axles
I think i do have a bad rack n pinion because it makes a nocking noise when i hit little bumps on the road.
My question is will a bad rack n pinion cause all that vibrations/shaking at 75mph and above??
Old Jun 1, 2010 | 09:05 PM
092eg6's Avatar
Default Re: Rack n pinion question
any1??
Old Jun 1, 2010 | 09:15 PM
Tyson's Avatar
sure.
install a new rack end bushing.
tighten the pinion before youre finished.
done. $15 in parts. lots of labor and annoyance but the learning curve is steep. totally doable tho.
lv6l
15
Jan 1, 2009 03:21 PM
Si-Samuri
May 15, 2008 11:39 AM
fbankins
Suspension & Brakes
Aug 8, 2006 07:03 PM
Fook_me_honda
Jun 24, 2006 12:05 AM
