Hydro Tranny In My EF Question
Im getting everything ready for my GSR so as soon as Midnight Finishes it i can just drop it in.
I already have an innovative mount kit for a cable B Series from an old swap. So what Else do i Need to buy to install my Hydro GSR Tranny?
Just a tranny mount an the Cable to Hydro Conversion Brackets? Or can i keep the cable tranny mount? Ive never looked at the tranny yet to see if they are differient.
Also, has anybody ever used the V2 Ebay Shift Linkage?
I cant wait for my GSR!!!!!
Its gonna be sooo much fun!
you MUST use the hydro mount. also you have to use the hydro "T" mount as they are different also.
and as far as ebay goes i dont use it- too many cheap built parts online.
but you can let us know how it works out
The "T" mount transmission bracket is from a 90-93 cable trans but you have to drill out the holes that the bolts go through to the transmission housing as the bolts for the hydro trans are slightly larger.
I would recommend using the Sonem kit for your hydraulic conversion as opposed to the type that still require the use of the clutch cable.
vtec25
17
Oct 3, 2006 06:57 PM
