Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Light bulb change
Old Jun 1, 2010 | 12:12 PM
96_civic_gsr's Avatar
Default Light bulb change
i need some pointers to change a light bulb for a 2004 civic sedan on the driver side everything is tight up in there powersteering and winshield reservoir, should i just take the headlight out or is there other ways to do it.
Old Jun 1, 2010 | 12:17 PM
Igaly's Avatar
Default Re: Light bulb change
u gotta go under the fender well
Old Jun 1, 2010 | 12:25 PM
jdmhondaes1's Avatar
all you have to do is take the power steering resevoir off its bracket and then you have access to the back of the headlight
Old Jun 1, 2010 | 01:26 PM
what about the winshield reservoir thats the only thing that doesnt give me enough clearance unscrew it.
Old Jun 1, 2010 | 04:04 PM
ya the windshield resevoir doesnt move nor should you have to unscrew anything to change the light bulb. move the p/s resevoir, unplug the connector, pull the rubber weather stripping off the back of the headlight, and unhook the gold tab that holds the bulb in place
Old Jun 1, 2010 | 06:39 PM
okay thanks i'll try that
Old Jun 2, 2010 | 05:12 AM
k27's Avatar
k27
pop out the tabs in your fender liner and pull it down and go up through there. It's pretty easy that way, I just did it this weekend.
Old Jun 2, 2010 | 10:35 AM
Jstans84's Avatar
I just took my windshield washer reservoir out, lol. The sprayers wouldn't fit in my carbon fiber hood and I lost some of the hoses so I just took the whole thing out, I never used to use it anyways. But yeah if it is gone you have extremely easy access to the back of the light. Otherwise you can just kind of jam your hand down in there and do it like that.
SteveP
Nov 26, 2017 01:19 PM
Lucman
Apr 10, 2008 02:35 PM
jsong921
Nov 27, 2005 03:34 PM
Boost2NA
Nov 17, 2002 12:11 PM
