Rear balance shaft drive gear
Old Jun 1, 2010 | 10:36 AM
sgraham01's Avatar
Default Rear balance shaft drive gear
94 accord lx. I have an oil leak at the lower end of the timing cover. I replaced the timing belt and components about 2 years ago along with the cam seal, crank seal and front balance shaft seal, but didn't remove the rear balance gear case to change the o-ring seal. I don't have the cover off yet, but I am guessing that maybe the oil is coming from the gear case. I priced the oring at $4 and the gear case at about $160. Question is... if it's the gear case that's leaking, is there a seal behind the balance sprocket that can be changed? i don't want to change the oring and still have a leak, and I don't want to spend $160 on the case if I can replace a seal inside it.
thanks
Old Jun 1, 2010 | 03:59 PM
phootbag's Avatar
Default Re: Rear balance shaft drive gear
The most common cause of a leak of this type is the case o-ring. Replace it, I'm sure you'll be fine.
gort
Feb 5, 2017 02:34 PM
mfrs
Feb 20, 2014 07:42 PM
djnikko
Honda Motorcycles
Jan 13, 2012 05:24 AM
minilogoguy18
Nov 24, 2010 04:37 PM
flyinga
Nov 24, 2004 12:56 PM
