Rev limiter on a pr3?????
Old Sep 12, 2002 | 09:37 PM
HybridRexy's Avatar
Default Rev limiter on a pr3?????
I have a pr3 and is the limiter suppose to kick in at 7800?? cause thats where mine kicks in. I have a 98 gsr cluster in it to and also when I had mt 89 crx one it bounced at 7800 to. I was thinking im losing 500 rpm in every gear if thats the case, cause a gsr rev limiter kicks at 8300 I believe?? + =
[Modified by HybridRexy, 6:37 AM 9/13/2002]
Old Sep 12, 2002 | 10:19 PM
Malgerus's Avatar
Default Re: Rev limiter on a pr3????? (HybridRexy)
I believe the rev limiter is set at 8200 RPM. Funny how yours kicks in early. Are you SURE you have the PR3 and not the PW0???
Old Sep 12, 2002 | 10:22 PM
HybridRexy's Avatar
Default Re: Rev limiter on a pr3????? (89_Y_49RIP)
definatly have a pr3, dunno why it kicks so early tho??
Old Sep 12, 2002 | 11:54 PM
Brandon Chun's Avatar
You're running a pr3 on your gsr motor?
Old Sep 13, 2002 | 02:29 AM
RexB16's Avatar
Default Re: Rev limiter on a pr3????? (Brandon Chun)
sure its not an auto ecu?
Old Sep 13, 2002 | 04:17 AM
HybridRexy's Avatar
Default Re: Rev limiter on a pr3????? (RexB16)
yea im runing a pr3 on my gsr and yea im sure its a manuel ecu
Old Sep 13, 2002 | 05:09 AM
model x's Avatar
It's an auto ecu. I had the same problem. Does vtec kick in at like 4800rpm? Just buy a chip of ebay to fix it and remove the speed limiter. But try and get one with the right rev limiter. The best I could find was 8600rpm.
Old Sep 13, 2002 | 08:35 AM
Default Re: Rev limiter on a pr3????? (model x)
The auto ecu kicks in at 7600, the manual pwo is 8000. Why not use a gsr computer?
Old Sep 13, 2002 | 11:50 AM
JALOP B16's Avatar
Are you throwing any codes?
Old Sep 13, 2002 | 03:14 PM
Francois's Avatar
Default Re: Rev limiter on a pr3????? (JALOP B16)
What about the secondaries butterfly?
Unless you have an ITR(modified) or a Skunk 2 intake,you may not have the full potential of that motor...
Old Sep 13, 2002 | 03:46 PM
91HATCH's Avatar
i have a mugen chip pr3 ecu if your interested....the way i drive i need a rev limiter
Old Sep 13, 2002 | 04:37 PM
r7's Avatar
r7
Default Re: Rev limiter on a pr3????? (91HATCH)
tach is not accurate
Old Sep 14, 2002 | 08:03 AM
HybridRexy's Avatar
Default Re: Rev limiter on a pr3????? (r7)
the tach has to be accurate and I also have a Vafc. I have a jg edelbrock manifold and that **** is slowing me down too!! I am interested in that mugen pr3, get back to me
Old Sep 28, 2002 | 02:29 PM
cloproductions's Avatar
how much for the pr3 chipped mugen ecu?
Old Sep 28, 2002 | 03:13 PM
Taloola's Avatar
Default Re: Rev limiter on a pr3????? (cloproductions)
i have a PYR programmed pr4 if anyone is interested. pm me
great ecu and in case anyone asks....it is vtec ready
Old Sep 28, 2002 | 08:14 PM
takeheed's Avatar
this is a reply for model x if a auto ecu kicks vtec in at 4800 what does a manual one kick in at?
Old Sep 29, 2002 | 07:46 AM
STK B16's Avatar
why dont u run a GSR ECU.. either that or choipp ur ECU.. then ur problems solved.
Old Sep 29, 2002 | 08:09 AM
n2o914drb16's Avatar
Default Re: Rev limiter on a pr3????? (Json79)
my old pr3 kicked in at 7800 and vtec at 4600......new pr3 10500 and 4400
severaltony
Mar 15, 2012 11:23 PM
kyle48_2007
Feb 6, 2010 10:31 PM
thewrai6th
Aug 14, 2007 05:44 PM
exhaust
Nov 17, 2001 04:40 PM
Chris_
14
Sep 27, 2001 08:28 PM
