What is this part? (pic)
Old May 31, 2010 | 05:09 PM
94h22a's Avatar
Default What is this part? (pic)
I found this sitting in the undertray when I took it out a few days ago. Who knows how long its been sitting there. This is in a 1993 Accord. Thought it would be a radiator mount or something but nothing appears to be missing when I looked. Any ideas?
Jon
Old May 31, 2010 | 05:46 PM
97AccordProject's Avatar
Default Re: What is this part? (pic)
Looks like the lower radiator mount that the radiator sits on.
At least that's what it looks like.
Old May 31, 2010 | 07:11 PM
crx_91si's Avatar
maybe for the drain hose for the evaporator box where it passes through the fire wall? Looks like it could be a firewall grommet of something.
#16 in the pic
how it would end up in the under tray is beyond me
Old May 31, 2010 | 07:37 PM
02 accord's Avatar
Shock mount bushing. 2 of those sandwich the tophat.
Old Jun 1, 2010 | 02:26 AM
fastlane2's Avatar
sway bar end link, I think, I'm half a sleep when I wrote this
Old Jun 1, 2010 | 07:37 AM
noe_h22accord's Avatar
That looks like a sway bar bushing how it got there idk..lol
Old Jun 1, 2010 | 09:51 AM
sgraham01's Avatar
from the size of it compared to the keys on the keyboard, it looks pretty large, maybe a front radius rod bushing? buddy of mine had his fall off the other day. fell out when he dropped the water shield from under the car. check the front of your radius rod where it bolts to the front subframe. if that's it, then you lost the nut and washer. number 15 in pic (pic is for a 94, but yours should be similar if not the same)
Old Jun 1, 2010 | 10:15 AM
TheMuffinMan's Avatar
He knows where you live!
It's not a sway bar bushing...
My vote is one of the following grommets
#10 in this diagram it's labeled as 15mm, looks like the inside diameter may be around that size.
Old Jun 4, 2010 | 09:09 AM
02 accord's Avatar
Looks like a radius rod bushing. Here's a pic of the 2 bushings with a shock mount bushing in the middle.
Old Jun 7, 2010 | 03:07 PM
94h22a's Avatar
Posts 7 and 9 were correct. Thanks guys! Will be fixing it asap.
Old Jun 7, 2010 | 07:24 PM
Senior Taco's Avatar
Ya definitely radius rod bushings as I was working with mine today
Old Jun 7, 2010 | 08:16 PM
02 accord's Avatar
You should probably change yours since you have it all apart. Took care of the wheel hop on my 02, 142k miles.
Scorpionking
Jun 3, 2014 10:09 PM
acmoc
11
Apr 5, 2010 04:05 PM
weiRtech
Welding / Fabrication
Apr 2, 2007 10:21 AM
whole9
Mar 31, 2007 03:23 AM
Sean @ ESG
30
Sep 28, 2005 12:44 AM
