obd1 injectors & egr ???'s
Well I'm have some problems here H-T. The first is to do with my egr valve. I have a 90 hf that a bough a few months back and the prev owner couldn't figure out what was wrong with it. I never figured it out either but I know it was to do with the hf mani. So I just swapped on my si intake mani and it starts and runs fine but its in limp mode due to there being no egr valve
. Is there a way to bypass or elimmate the egr valve without throughing a code? Or am I going to have to just get a new egr and swap back on the hf mani?
2nd is the injectors, there starting to go on me. I do have a set of obd1 injectors that I'm going to use when I convertor over to obd1 but in the mean while can I just eliminate the resistor box, swap the injector clips over and use them with my obd0 ecu?
. Is there a way to bypass or elimmate the egr valve without throughing a code? Or am I going to have to just get a new egr and swap back on the hf mani?2nd is the injectors, there starting to go on me. I do have a set of obd1 injectors that I'm going to use when I convertor over to obd1 but in the mean while can I just eliminate the resistor box, swap the injector clips over and use them with my obd0 ecu?
but its alot easier to just unplug a ecu and plug another in then cud wires solder them and change injectors when u could have it running within pushing 3 clips on a ecu and 4 nuts on the cover
nickeynick
Jun 29, 2009 08:52 AM
