stock pump and fpr with 50 shot wet??
Old May 31, 2010 | 08:30 AM
blasterman87's Avatar
Default stock pump and fpr with 50 shot wet??
can i run a 50 shot wet shot from a zex kit with my stock si fuel pump/fpr? it says in the manual that i need 38psi if fuel pressure to run the nitrous, and i cant find a straight answer if the stock system has 38..?
Old May 31, 2010 | 12:06 PM
Default Re: stock pump and fpr with 50 shot wet??
all i can find is stock fpr has 35-40 psi is that true?
Old May 31, 2010 | 12:19 PM
jspeccrx91's Avatar
don't remember what fuel pressure is on a single but i hit my old d16 si motor with a nx wet 60 shot for over a year squeezing every weekend. car/motor was stock minus intake and header so you should be fine.
Old May 31, 2010 | 04:25 PM
1990hondacrx's Avatar
you will be fine u can run up to a 75 shot before needing bigger pump i ran a 65 on my b16 setup I H and bolt ons with no issues
LiL JoN
Feb 17, 2006 07:02 PM
spun Vtec
12
Mar 14, 2005 01:51 AM
DarkBB4
Nov 4, 2004 12:18 PM
99cvcdx
Mar 11, 2003 08:07 PM
itr--779
Jul 27, 2001 02:17 PM
