15' work vs xx
quick question. I been searching and i haven't found anything about these in 15's. i just bought a set and i was wondering if there 3 piece or 2? can the lip be change to make them wider like bbs wheels?
thanks!
thanks!
no, there arent any replacement aftermarket lips for these like bbs wheels have... you would need to locate another set of works and swap barrels from there and/or rebarrel them.
bbs wheels are stepped and vs-xx lips are straight reverse. the vs-xx is a 3 piece wheel. im not sure if the lips is welded or detachable.
and stop bumping. this is a slow moving forum. no need to bump to the top. you will get your answer eventually. you just need to wait and be patient.
