should i get obd1 comp. with chip or skunk2 manifold
Old Sep 12, 2002 | 08:28 PM
chingchong's Avatar
Default should i get obd1 comp. with chip or skunk2 manifold
i have a 2000 gsr with i/h/e and skunk stage one, what should i get next? a p28 with a chip or skunk2 intake manifold?
Old Sep 12, 2002 | 08:52 PM
Trigun's Avatar
Default Re: should i get obd1 comp. with chip or skunk2 manifold (chingchong)
skunk 2 manifold
Old Sep 12, 2002 | 08:57 PM
metal-x's Avatar
Default Re: should i get obd1 comp. with chip or skunk2 manifold (Trigun)
skunk2 manifold
Chip it
Old Sep 12, 2002 | 09:21 PM
Full Race EG's Avatar
Default Re: should i get obd1 comp. with chip or skunk2 manifold (metal-x)
Go with the Skunk 2 manifold
Old Sep 12, 2002 | 09:34 PM
PoW3l2BaN's Avatar
the skunk2 manifold wont give you the power you want unless you get teh p28 to go along with it...you will lose some low end HP with the manifold itself cause yer stock ecu still thinks you got that second butterfly...and yer vtec will switch on at 5500rpm or so instead of the 4400 which the gsr's are at....search around the forums.,.you'll find something about it...basically...you cant go manifold without the p28 or so ecu...
Old Sep 15, 2002 | 11:31 AM
TimoneX's Avatar
New User
Default Re: should i get obd1 comp. with chip or skunk2 manifold (PoW3l2BaN)
That last post made no sense whatsoever. Of course you can go Skunk2 manifold w/o the P28...or P72 OBDI for that matter(which is actually a better choice). That said I'd eventually try to find a compatible OBDI ECU whether P72, P30, or P28, but do the manifold first, the ECU even chipped will not make much difference to you, unless you're trying to run a test pipe.
Old Sep 15, 2002 | 03:59 PM
PoW3l2BaN's Avatar
Default Re: should i get obd1 comp. with chip or skunk2 manifold (TimoneX)
im sorry i meant you dont want to go skun2 manifold without the perfect ecu and tuned timing/fuel maps..p72 ecu will work but like i said.you will lose lots of low end..heres the link:
https://honda-tech.com/zerothread?id=258014
Old Sep 15, 2002 | 06:42 PM
TimoneX's Avatar
New User
The accepted philosophy is that you do the chip last. It makes allot of sense, though I hope I'm never "done" modding my car. I have heard tell that you do lose a bit of low end power with the skunk2 IM, but I don't believe it's all that significant.
Old Sep 15, 2002 | 08:54 PM
IgniteTeg's Avatar
no doubt skunk2 im then afterward convert to obd1 p72 ecu.
Fat Chick Magnet
Dec 12, 2006 02:17 PM
gsrvtec2
Oct 28, 2005 05:08 AM
petersayarath
Aug 16, 2004 09:50 AM
xplanetearth420x
Apr 22, 2004 09:28 PM
