AC back into EF with B swap
Old May 30, 2010 | 06:13 PM
lilhatch89's Avatar
Default AC back into EF with B swap
I Know this has probably been anwser a million times but for the life of me I cant seem to find it anywhere. Im reinstalling teh AC back into my Sedan, it has an LS Swap. I noticed that the Saden Compressor Will bolt up to the Integra bracket with the Exception of two rear bolts. My question is this will the front two bolts hold it fine, or should i have the rear two holes drilled and tapped as well. Also Anyway to test the wiring before I go installing the ac back into the car. I would like to make sure any electrical Problems are solved while all the lines are out.
Old May 30, 2010 | 06:31 PM
thiendegigolo's Avatar
Default Re: AC back into EF with B swap
knowing that the compressor belt will also be driven off the crank. IMO would rather bolt it ALL DOWN.
Old May 30, 2010 | 06:37 PM
lilhatch89's Avatar
thats What im thinking atleast one bolt on the back would be good i may just drop it off and have it drilled and tapped for the bolt on the back and run with it.
Old May 30, 2010 | 06:50 PM
lilhatch89's Avatar
I know i have seen a couple people on here run the integra bracket just dont know if they ran just two bolts or what Hope to see them chime in.
Ef4doorwagon
Jun 6, 2014 04:47 PM
Civic361
Jul 28, 2011 09:17 PM
EFin Baby J
Jun 30, 2011 11:42 AM
bankhead83
Aug 23, 2005 12:16 PM
