5th Gen 94-97 Wheel TEch Question ???
Old Sep 12, 2002 | 07:30 PM
xunkn0vvnx's Avatar
Default 5th Gen 94-97 Wheel TEch Question ???
Noooo... I need help finding some rims.... I need the stock wheel sizes .... what rim size will i be able to use, what bolt pattern, and what offset ??
it is a 1994 4 door honda accord EX....
Old Sep 12, 2002 | 07:33 PM
Nick H's Avatar
New User
Default Re: 5th Gen 94-97 Wheel TEch Question ??? (xunkn0vvnx)
i recomend anything from a 15" whel to a 17" wheel...the stock fender wells will let you stick 19's in there, but i would definitely not suggest this...the bolt pattern for the 5th gen is a 4x114.3 mm...and any offset from 38mm to 44mm will work...i'm sure other offsets will work, but those are common offsets...so yeah...
Old Sep 12, 2002 | 07:54 PM
xunkn0vvnx's Avatar
Default Re: 5th Gen 94-97 Wheel TEch Question ??? (nickh2k1)
thanks bro... that was quick
Old Sep 12, 2002 | 07:59 PM
xunkn0vvnx's Avatar
What other cars have compatible bolt patterns with the accord ??
what is universal lug pattern
[Modified by xunkn0vvnx, 6:00 AM 9/13/2002]
Old Sep 12, 2002 | 08:00 PM
ArchAngel Sabastian's Avatar
New User
ehh.. prelude..rims?
Old Sep 12, 2002 | 08:03 PM
urbanlegend21's Avatar
New User
Default Re: 5th Gen 94-97 Wheel TEch Question ??? (ArchAngel Sabastian)
prelude = yes
Kosei K1's 15x7 are the perfect rim because the offset allows you to fit 225/50/15's without wheel studs and spacers
Old Sep 12, 2002 | 08:04 PM
Brandon's Avatar
Life is Suffering
Default Re: 5th Gen 94-97 Wheel TEch Question ??? (urbanlegend21)
prelude = yes
Well, 225/50/15's are the wrong aspect ratio though.
Old Sep 12, 2002 | 08:12 PM
Kazmans94cord's Avatar
brian and i have a secret...we will shock you all...muahahahahahahahahahahahahaha....muuuuuahaha hahahahahahahahahahahahah
Old Sep 12, 2002 | 08:15 PM
Brandon's Avatar
Life is Suffering
Default Re: 5th Gen 94-97 Wheel TEch Question ??? (oh so HIGH y0!)
When are you two kids going to come out of the closet?
Old Sep 12, 2002 | 08:32 PM
New User
Default Re: 5th Gen 94-97 Wheel TEch Question ??? (B the Turbo Pimp)
ok explain that?
Old Sep 12, 2002 | 08:36 PM
95 GaNgStA AcCoRd's Avatar
I'm lost, but it was funny to read anyway.
Old Sep 12, 2002 | 08:39 PM
shut your mouth you sick freak! your just jealous! o0?
Old Sep 12, 2002 | 09:26 PM
Razor's Avatar
i always get this confused, does a larger offset make the wheel stick out more or what?
Old Sep 12, 2002 | 11:57 PM
TypeSH's Avatar
Default Re: 5th Gen 94-97 Wheel TEch Question ??? (Razor)
do they make K1's in 4x114.3?? i always thought they only came for civic/integra's 4x100.
and for 5th gen accords that have 195/60/15 stock wheels (24.2" diameter), i think 225/50/15 is the closest w/ 24" diameter?
In any case, what 225/50/15 tires are you guys using? and what offset would you need for 15x7 wheels?
on the side, how about 16x7 wheels, thats what I was thinking of getting. I figure there are more tire options w/ 16x7 than 15" wheel and i dont need to goto 17" w/ extra wheel weight.
[Modified by TypeSH, 8:59 AM 9/13/2002]
Old Sep 13, 2002 | 05:02 AM
Gennady's Avatar
New User
How come 4doorH22 has to use longer studs and spacers to use with his 15x7 K-1's and 225 sectional tires? Can you order K-1's with custom offsets?
Old Sep 13, 2002 | 05:04 AM
WuWarrior's Avatar
prelude = yes
Actually 225/50/15 is perfect for an Accord if you are going to race. But for the street, go with 205/60/15.
Old Sep 13, 2002 | 05:11 AM
Gennady's Avatar
New User
Default Re: 5th Gen 94-97 Wheel TEch Question ??? (WuWarrior)
205/60/15.
False info alert.
Old Sep 13, 2002 | 05:21 AM
greensleeper's Avatar
the smaller the offset the more your wheels stick out. I'm pretty sure that the offset number is the distance between the center line of the wheel and the hub/rotor mating surface. So as that the distance decreases the center line of the wheels moves further and further out...
look at my pics in my sig. 17x7's with 37mm offset. Perfect.
[Modified by greensleeper, 8:22 AM 9/13/2002]
Old Sep 13, 2002 | 05:48 AM
p0pe's Avatar
Default Re: 5th Gen 94-97 Wheel TEch Question ??? (greensleeper)
So a +38 offset would be better than a +42 for 16x8"s right? Greensleeper do you have any rubbing with those wheels?
Old Sep 13, 2002 | 04:18 PM
xunkn0vvnx's Avatar
Default Re: 5th Gen 94-97 Wheel TEch Question ??? (p0pe)
is 205 tires bigger than 215 ??
Old Sep 13, 2002 | 04:20 PM
Accord94DX's Avatar
When you pop out with Gennady.
Old Sep 14, 2002 | 12:26 AM
TypeSH's Avatar
obviously no.
Old Sep 14, 2002 | 08:21 AM
WhoNeedsVtec's Avatar
Default Re: 5th Gen 94-97 Wheel TEch Question ??? (TypeSH)
the first number 205, 215 etc is the width of the tire. then the second number say 40, 45, 50 etc, is the precentage of the width for the side wall. make sense?
MakoE2
May 8, 2005 03:16 PM
RTW DC2R
Mar 16, 2003 11:01 AM
freeplay
Feb 28, 2003 03:30 PM
020
Feb 20, 2003 08:45 AM
