engine swap help!!
Old May 29, 2010 | 10:26 AM
Lao17's Avatar
Default engine swap help!!
i have a 91 ef hatch and im putting a 99 ls motor in it and need to know if a 91 ef si engines harness will work with the motor.
Old May 29, 2010 | 10:52 AM
90efhatch's Avatar
Default Re: engine swap help!!
You might have to extend a few wires but it should work.
Is the car MPFI wired already?
Old May 29, 2010 | 01:47 PM
Lao17's Avatar
no i havent started the swap yet. cause i dont have a engine harness for my ls. and i didnt wanna start it til i was sure that a ef si engine harness would work on an obd2 ls motor
Old May 29, 2010 | 01:55 PM
evo500's Avatar
i would figure it will fit capt.
Old May 30, 2010 | 06:03 AM
jlicrx's Avatar
the Si engine harness will only work if your car is the Si model
Old May 30, 2010 | 06:11 AM
k20rex's Avatar
if your car is not an si model use a dx harness converted to mpfi
Old May 30, 2010 | 08:20 AM
dr_latino999's Avatar
As others have said, the key is taking your original harness and adding subtracting as deemed necessary. Take your OEM harness and if necessary, add the MPFI extensions and then worry about extending the wires necessary to reach relocated sensors.
Old May 30, 2010 | 09:15 AM
Lao17's Avatar
ok thanks for the help
Old May 30, 2010 | 09:52 AM
Lao17's Avatar
i know this is probably a stupid question for you guys but this is my first ef so i dont know much about them. but what is the mpfi that i need to wire? haha
Old May 30, 2010 | 09:59 AM
beansandrice's Avatar
If you have a DX model it will be a dual point dpfi. MPFI means multi point
f i is fuel injection
Old May 30, 2010 | 10:00 AM
here you go have fun
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
Old May 30, 2010 | 10:12 AM
waspcrx19's Avatar
I dont mean to thread jack but i seem to have a lil similar problem with my swap. if anyone can help out check out my profile under the bodyharness.
Old May 30, 2010 | 10:24 AM
Lao17's Avatar
the origianl motor that was in it was a obd1 gsr. i bought my ef as a shell. so should i be good then with the mpfi?
Old May 30, 2010 | 10:28 AM
Lao17's Avatar
atcually a buddy of mine is gonna give me a obd0 ls harness. that should work fine for my 99 ls motor right?? lol
Old May 30, 2010 | 05:16 PM
quartermilerun's Avatar
It should if ur using obd0 dizzy if not get jumper or make one pretty easy and yeah extend wires get rywires for ecu jumper
Old May 30, 2010 | 06:59 PM
No, you need to work with your factory harness unless you plan on rewiring the engine + chassis harness at the same time. If you are up for that, power to you, if not, work with what you have, in the end it usually saves time and energy.
Old May 30, 2010 | 07:10 PM
blasterman87's Avatar
the harness you have will work perfect. esp if it had a gsr before the plugs for the ls are all the same
Old May 30, 2010 | 10:39 PM
BadassEFdriver's Avatar
What if i Have a 97 obd2 B18B1 ls and I have a harness for an obd0 B18A1 ls? would that plug right up to a crx si harness and the motor as well, without having to do any wiring?
Old May 31, 2010 | 06:02 AM
No
Old May 31, 2010 | 06:05 AM
the harness you have will plug right in and run the b18 as long as you get a obd0 dizzy, and remove the resistor box from the car. cut the wires going to ii and solder all 5 together. that will allow you to run obd1/obd2 injectors
Old May 31, 2010 | 09:57 AM
Yeah i knew you had to change the injectors & dizzy wasnt sure about all the sensors, okay that makes since thanks. I have obd0 injectors i plan on running cus i dont wanna cut the harness, Do I need to leave the resister box there If I do. yes
Old May 31, 2010 | 12:04 PM
yeah leave the box if you use obd0 inj.
Old May 31, 2010 | 07:51 PM
[QUOTE=blasterman87;42628562]yeah leave the box if you use obd0 inj.[/QUOT
cool thanks!
turbob18si
Sep 8, 2011 11:18 PM
tremon3y
27
Dec 27, 2010 01:32 PM
97ekb18b
Feb 22, 2009 06:15 PM
Paco_ef
Aug 25, 2008 09:52 AM
Bseries!EF!hatch
May 19, 2006 08:24 AM
