MINNESOTA-H2B Ef swap-ready to drop in(still in running car)
Old May 29, 2010 | 10:19 AM
thevtecnician's Avatar
Default MINNESOTA-H2B Ef swap-ready to drop in(still in running car)
Selling my H2B swap. This thing is ready to go into your car and literally everything is included. Engine is still in the car so you can test drive it (with cashola present)
Bought this engine in 2004 from venus auto in Sacramento California.
Be fore the engine went in in november 2008, I replaced the following, and added the following:
-new water pump
-new timing belt
-h23 manual timing belt tensioner conversion
-new spark plugs + wires
-obd1 jdm internal coil dizzy
-ESP H2B 4-2-1 race header
-custom straight pipe
-ESP alternator relocation kit for use with d series alternator
-profab intake maniold gasket
-rosko racing TB gasket
-S2 70mm throttle body (port matched by myself at home)
-QSD h2b kit.
-crome'd P06 ecu, street tuned in CA for safe air/fuel mixture
-boomslang jumper harness
-Kaizen speed balancer shaft eliminator kit(only block off plate is in use, but I will give you the rest of the kit with it)
-machined crank pulley for clearance
-J1 cable transmission (has slight issues, nothing major)
-toda 7lb flywheel recently resurfaced
-act heavy duty pressure plate, 6 puck unsprung clutch disc
-re-welded da shift linkage(shifter leans a bit towards the driver, but i thought that was cool )
-da axles and half shaft
-OLD school hasport mounts
-da rear t bracket
-EGR, and IAB deleted
-AEM fuel rail
-earls -6 fuel line setup(hose, lines, fittings, filter, everything)
Motor runs great and pulls hard. No smoke, or leaks, etc.
Asking price is $3000 for all of this.
$3200 with the custom Renown tuck harness, which will make the swap a plug and play affair.
THE SWAP WILL COME WITH A STOCK VC. THANK YOU.
Old May 29, 2010 | 05:34 PM
4NLINE UNLIMITED's Avatar
Default Re: MINNESOTA-H2B Ef swap-ready to drop in(still in running car)
Same Swap from the RHD EF8 also?
Old May 30, 2010 | 08:43 AM
Yeah. except is has a shorter geared transmission now.
Old May 30, 2010 | 11:56 AM
Robs_B18c's Avatar
Have you had it on a dyno? How is the hood clearance?
Old May 30, 2010 | 04:16 PM
Nope, not been dyno'd yet.
In california, I had it street tuned using a wideband just for safe air/fuel mixture. Needs a retune now though due to the different sea level out here.
Old May 30, 2010 | 04:19 PM
Hood clearance depends on your setup. In my crx with the jdm front end I only needed 1/4" injector spacers for the hood. In my ef sedan with the stock hood, I had to make a custom jdm style cowl.(sort of like the jdm hoods' raised center section)
Old Jun 8, 2010 | 04:02 PM
Any interest?
If there's anyone looking for a car, I'll sell the swap running an an ef sedan from california. Tein suspension, integra brakes, power everything. $3300 for the running car with this swap.
Old Jun 19, 2010 | 02:42 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
pm sent
Old Jul 22, 2010 | 06:55 PM
K-EG's Avatar
Still for sale?
webster426
Honda Civic (2001 - 2005)
Jul 6, 2009 05:06 PM
G35toEFcivic
Aug 19, 2006 05:52 PM
J.B.
May 6, 2005 08:42 AM
iwhichisme
Aug 13, 2004 08:28 PM
Achenar
Jul 22, 2004 04:12 PM
