81.5mm Piston Rings
Old May 29, 2010 | 09:22 AM
SR20S13's Avatar
Default 81.5mm Piston Rings
so i bought a rebuild kit, and well i got 81.5mm pistons and umm they came with 81mm piston rings, so what should i do now?
Old May 29, 2010 | 09:29 AM
projectTeG's Avatar
Default Re: 81.5mm Piston Rings
buy 81.5 mm rings? and please buy good ones,,, no cheap ****.
go with npr gnh rings or at least hastings. i dont believe oem comes in that size
ive had oiling issues with the yellow brown box npr rings
Old May 29, 2010 | 10:08 AM
SR20S13's Avatar
any idea where i can buy them?
Old May 29, 2010 | 10:51 AM
dester223's Avatar
The hasting rings are really decent. Are you 100% sure it's 81.00 rings? I know the hastings ring kit has the 81mm part # on them, then on the end has .020 on it. And the box reads 81mm also. But with the ".020" at the end of the part number, they are 81.5mm rings.
Old May 29, 2010 | 03:21 PM
SR20S13's Avatar
i'll have to check it out
Old May 29, 2010 | 04:21 PM
CRX-Kid11's Avatar
i used perfect circle rings for my 81.5 lsv and havnt had any problems
ZCHondaCRX91
Engine Machining & Assembly
Sep 14, 2015 04:23 PM
rocket_R
Jun 13, 2006 11:11 PM
riceball777
Jan 17, 2004 09:41 PM
