help...car wouldn't start.
Old May 28, 2010 | 11:52 PM
bp's Avatar
bp
Default help...car wouldn't start.
I have an 88 crx si that was parked for about 5 months untouched. The car started and ran when parked. I am unable to start it now. It cranks fine. So far I did the followings.
1) drained fuel tank and new gas.
2) new coil and ignitor- don't have a ohm meter to test output of coil but was able to get constant positive with check light at positive terminal of coil. But I get no spark with spark plug pulled and grounded on valve cover ground.
3) new main relay installed but I get no clicking with the new or old main relay.
4) ground at thermostat is good- Is there any other ground?
5) check engine light stays on when key switch in ignition position.
6) No activity at led on ecu at all.
Any suggestions would be greatly appreciated.
Joe19
Apr 11, 2019 05:41 PM
JdmCrx209
Jul 17, 2011 10:24 PM
shaved4dr
Oct 29, 2006 06:38 PM
Ideal
Nov 6, 2002 02:08 PM
No More Civic
10
Aug 27, 2002 09:35 AM
