97 Accord Shifter Bushings
Accords don't need that because the shifters are connected directly to cables and then to the transmission. There are no bushings (expect the ending link connected to the shifter itself) that you could replace to feel a dramatic difference.
You've got the idea from hearing about civics probably.
there are bushings corsport has come out with. i have the ones from the 06 civic si installed in the cable ends. makes the shifting more precise. check them out. i think u can make the shifter base bushings fit too.
Tx92AccordExD
Feb 27, 2003 10:56 PM
