arps, pistons, lights, crx int, ZC block, crank
Old May 28, 2010 | 05:05 PM
qweakers's Avatar
Default arps, pistons, lights, crx int, ZC block, crank
unless noted prices do not include shipping and/or fees
DOHC ZC block, fresh bore to 75.5 75 ish
some surface has started setting in from sitting in the house for 3 days, dang swamp cooler
i do have the main bolts, just need to find them
DOHC ZC crank 75 ish
90-91 crx dx wiring, main, rear, dash (getting pic), engine (missing one plug, i have it just have to find it) 125 ish
not looking to separate right now
14point7 wideband with gauge, bought from someone here new, i never used it 50 ish
crx shift linkage, stock 30 ish
crx rear triangle garnish things 15 ish ea
incomplete arps DOHC zc 25
valve covers 25 ea
new arias pistons, d16a6, 75.5, low compression, needs new pins 225 shipped
flat rate special parts, whatever can be jammed in a flat rate for $10 be it one to twenty peices plus the cost of the flat rate box (providing it fits) and fees FYI more parts in less room for packaging material
in the event parts do not fit in a flat rate they will have to be shipped via fedex, same deal just more you add the more the shipping cost may be becuase of weight
bumper lights are not perfect
blue crx interior pieces $15 ea anything less not really worth the time to package it
90-91 crx tails 20 ish ea
have flaws, while my in depth description may scare some to other these flaws may be acceptable, for what ever reason i am very critical in these cars and lights so the slightest flaw gets the boot or redone. so to some this may be a deal
3-4 inch crack by right reverse light in the red, scratches here and there
pressure cracks on the big red part, not totally threw plastic if you know what i mean, slight scuffs to little red part
damage to orange lens, rock chip like looking spidering, can be seen in pic, look hard
3-4 inch crack in big red part, slight pressure cracks here and there
automatic halfshaft 35 ORO
Old May 30, 2010 | 08:29 PM
qweakers's Avatar
Default Re: arps, pistons, lights, crx int, ZC block, crank
stock tophats sold
qweakers
Jun 13, 2010 10:45 PM
qweakers
Texas -OK -LA (Sales)
Jun 13, 2010 12:03 PM
CRX_RUS
Aug 15, 2004 09:04 AM
crxtreme27
Apr 28, 2003 09:26 AM
