fuel/ecu?????
so i have a 90 crx dx with a b18b1 in it
someone else did the mpfi swap and its been converted to obd1 still running obs0 injectors
i was tucking everything and fixing the half a$$ wiring that was done before
now im throwing code 16 and 9
as far as the fuel goes.. its just dumping it constantly into the motor, you can smell it bad
so the only thing i can think of is a bad wiring or switched or something
my question is can i just directly wire each injector to the correct ecu pin?
im running a p75 ecu
