Built dart turbo motor, rc, peak boost, crowed, cams, big powa!
dart block 84.50mm bore
LS crankshaft*
JE pistons 9.3:1 compression,upgraded wrist pins and piston rings
Eagle H-beam rods
Moroso 5.5 quart deep sump oil pan with pickup
Type R oil pump
Cometic extreme duty head gasket*
ARP head studs
Golden Eagle head dowels
B16 head
3angle valve job, ported head
Stainless Crower 1mm oversized intake valves, .5mm oversized exhaust valves
Crower stage 2 turbo cams
Crower duel vavle springs with titanium retainers
Crower adjustable cam gears
TODA timing belt
CTR crank pulley
King Motorsports extended intake manifold studs
Stainless ARP exhaust manifold studs
Edelbrock Victor X intake manifold with Edelbrock throttlebody
stock fuel rail
B&M fuel pressure regulator
RC 750cc saturated fuel injectors
4500$ for the long block, 3500$ if it's a sort block, 1600$for the head complete with cams etc. 500$ for manifold with jg throttle body.
Turbo
Precision SC60 turbo
Peak boost ramhorn turbo manifold
Tial 38mm wastegate*
Tial B.O.V.
1700$ for the tubo parts together
__________________
Send me a pm will only trade for a "nice car of eqaul value for all the parts" jdm front end for dc2. And real dc2 parts plus cash, no I don't want rotas or D2 or low end knock of stuff
LS crankshaft*
Eagle H-beam rods
Type R oil pump
ARP head studs
B16 head
TODA timing belt
CTR crank pulley
stock fuel rail
Turbo
Tial B.O.V.
__________________
slick1851
Jul 1, 2010 09:19 PM
slick1851
May 29, 2010 10:48 AM
