Going to do a j swap turbo parts and nasty DART motor forsale
Old May 28, 2010 | 10:45 AM
slick1851's Avatar
Default Going to do a j swap turbo parts and nasty DART motor forsale
Engine
dart block 84.50mm bore
LS crankshaft*
JE pistons 9.3:1 compression,upgraded wrist pins and piston rings
Eagle H-beam rods
Moroso 5.5 quart deep sump oil pan with pickup
Type R oil pump
Cometic extreme duty head gasket*
ARP head studs
Golden Eagle head dowels
B16 head
3angle valve job
Stainless Crower 1mm oversized intake valves, .5mm oversized exhaust valves
Crower stage 2 turbo cams
Crower duel vavle springs with titanium retainers
Crower adjustable cam gears
TODA timing belt
CTR crank pulley
King Motorsports extended intake manifold studs
Stainless ARP exhaust manifold studs
Edelbrock Victor X intake manifold with Edelbrock throttlebody
stock fuel rail
B&M fuel pressure regulator
RC 750cc saturated fuel injectors
4500$ for the long block, 3500$ if it's a sort block, 1600$for the head complete with cams etc. 500$ for manifold with jg throttle body.
Turbo
Precision SC60 turbo
Peak boost ramhorn turbo manifold
Tial 38mm wastegate*
Tial B.O.V.
1700$ for the tubo parts together
TURBO KIT SOLD TURBO KIT SOLD TURBO KIT SOLD!!!!!!!!!!
Old May 28, 2010 | 01:17 PM
H22Ej1's Avatar
Shenanigans
Default Re: Going to do a j swap turbo parts and nasty DART motor forsale
up for a j...what motor/trans setup are you planning for?
Old May 28, 2010 | 01:28 PM
integradc4_rg87's Avatar
how much for the tial wastegat
Old May 29, 2010 | 06:25 AM
slick1851's Avatar
220$
Old May 29, 2010 | 06:26 AM
slick1851's Avatar
Tl type s or CL type s
Old May 29, 2010 | 10:48 AM
slick1851's Avatar
DONT TELL ME MY MOTOR ISNT WORTH MONEY BECAUSE ITS NOT IN A RUNNING CAR LOL!****EN MORONS!
SOLD THE TURBO SETUP
slick1851
Jul 24, 2010 03:05 PM
slick1851
Jul 24, 2010 10:30 AM
slick1851
Jul 1, 2010 09:19 PM
slick1851
Jun 8, 2010 12:20 PM
wyte_rice
Apr 4, 2010 02:37 PM
