regular gas comp ratio
Old May 28, 2010 | 05:55 AM
HyperFlow's Avatar
Default regular gas comp ratio
Whats the highest compression ratio i can go and still use regular gas?
Old May 28, 2010 | 06:11 AM
Mr_ET's Avatar
Default Re: regular gas comp ratio
like 87 regular gas or 91?
I would guess 10:1 on regular is probably the max. It all depends how hot it is in your area and how conservative the timing maps are in your ecu. Altitude will also be a factor.
Old May 28, 2010 | 06:30 AM
neverstop's Avatar
this has been covered many times on here, its not as simple as that, browse the dyno results thread and find a build you like and then use that compression ratio
Old May 28, 2010 | 08:29 AM
DDTECH's Avatar
i'm at 13.0CR daily driven, if the tune is good you shouldn't have a problem..running anything lower.
Old May 28, 2010 | 08:35 AM
neverstop's Avatar
I daily drive with ~12.0 compression ratio, definately need to get it tuned by a pro though or motor won't last long. I think consensus is that anywhere in the 11.8-12.5 range is fine for pump gas
Old May 30, 2010 | 06:55 AM
HyperFlow's Avatar
i ment 87oct, im at sea level and its fairly cold here never really get avg temp would be 60-70deg.
JonDick
Dec 20, 2010 10:27 PM
blackeg
Jul 17, 2008 07:52 PM
jdm_SirG
Mar 8, 2006 02:37 PM
Justin Olson
Jan 13, 2006 04:28 AM
JsNA99si
Jun 16, 2004 02:51 PM
