F/S: Complete D16y7 swap
Complete 1998 D16y7 swap converted to OBD1. It is currently in my Del Sol so you can hear it run.
Swap includes:Wire harness,mounts,ecu,axles, and p/s pump.
Compressions #'s: 168-174-163-175
D16y7 engine (unknown miles)
--y8 intake manifold.
--Header
--A/c compressor
--Alternator
--New driver belts, spark plugs, thermostat
--Cleaned throttle body & IAC valve
--Does not SMOKE,LEAK,or KNOCK.
--All 3 coolant related sensors replace. (ECU,fan,& Coolant gauge)
5sp transmission:
--Newer clutch
--New slave cylinder
--cv axles & boots good shape. no cracks
Swap will include shift linkage for either 92-00 civic or 93-97 del sol.
Transmission does grind shifting into 3rd at higher rpms.
Price: $325 obo. Make offer. NEED TO SELL!!
Call/text 901-233-8654
--Header
--A/c compressor
--Alternator
5sp transmission:
--Newer clutch
I would like to sell everything together first. I am going to a b-series so I will have no need for the extra parts. If noone buys the swap after a while, I will consider parting it out.
