should i trade my kicker L5 12 for punch P2?
Old May 27, 2010 | 10:00 PM
TravisCadello's Avatar
Default should i trade my kicker L5 12 for punch P2?
i had 2 tens that were bangin sounding really good crips bass but then one blew. so i got a 12 solo baric L5 kicker for cheap 80 bux but i put it a super small crappy enclosed box.
its sounds OK but reason i wanna trade for punch p2s is because their a pair and easier to push my l5 is a single. do you guys think its a good trade? my amp is a precision power dcx500.1 2 chanel i paid 375 for amp but only 500 watts.
the p2s any good?
Old May 27, 2010 | 10:18 PM
mrdeadman's Avatar
They let me pick
Default Re: should i trade my kicker L5 12 for punch P2?
Did you get the 2 or the 4 ohm L5?
If it is the dual 2ohm you can wire it in series to get your 500watts.
Those P2s are dual 2ohm. If you got both of them you would only be able to run 125w to each of them which means you'd need a new amp if you really wanted them that bad.
I'd keep the L5 and throw it in a bigger box. Probably ported. Although it's not really a good match for the amp either. It's rated for 600wrms.
http://carjamz.com/zen/index.php?mai...roducts_id=172
http://www.kicker.com/solo-baric_L5
http://www.rockfordfosgate.com/produ...8&locale=en_US
You could get 2 4ohm DVC and wire each sub's VCs in series. Or two 2ohm SVC and wire each one to a separate channel. These would all need to be rated at 250rms or less though. This would be a better solution. Unless you want to sell the amp and start over.
Old May 28, 2010 | 12:33 AM
edzy's Avatar
No.
Put that l5 in a well built ported box..
Old May 29, 2010 | 07:19 AM
ken9's Avatar
I would keep kicker because those are good sub.. I use to be owner of those kicker sub..
Old Jun 4, 2010 | 07:58 PM
Art8609's Avatar
Keep the kicker!!! Just get a better box for your setup. It all depends on what youisten rock, hop hop, etc.
818_crx
Apr 9, 2010 01:55 PM
HONDA-2NR
Apr 15, 2005 11:32 AM
D for D series
Audio / Security / Video
Feb 6, 2005 12:29 PM
