swapable parts from b2 to a6? and other q's
Old May 27, 2010 | 08:40 PM
CRXguy_88's Avatar
Default swapable parts from b2 to a6? and other q's
Hey was wondering if alternator, starter would swap onto an a6 i just bought from my b2? also could i use an ef si engine harness or ecu or do i need a crx si stuff? and for that matter does the harness need to match motor year?
Is an ef si dizzy, ecu, intake mannifold, wire harness & or resistor the same as crx si? and could i use it with my a6? my crx is a dx..
if theres a list of stuff that can swap would be helpful and suff that wont work as well would help too.. thanks
Old May 27, 2010 | 09:28 PM
BiG ChOr!Zo's Avatar
Default Re: swapable parts from b2 to a6? and other q's
you can use the same alternator and starter from the b2 on the a6...also use your existing engine harness if your staying dpfi or going mpfi.
if your going mpfi you need a td-02u or td-18u dizzy,pm6 ecu,a6 or zc sohc intake manifold and a resistor box from a si.
search the faq section on how to do a mpfi swap
Old May 27, 2010 | 09:32 PM
CRXguy_88's Avatar
but do you know if ef and si stuff are similar? if not its cool.. i appreciate for what you helped me with
Old May 27, 2010 | 09:51 PM
ef=rhd
ed=lhd
usdm si and zc sohc motor parts are the same...!!!
Old May 28, 2010 | 04:33 PM
CRXguy_88's Avatar
I mean "USDM" 89 91 civic si parts.. in that response lol sorry so many people call theirs an "ef" but its whatever i guess. soo...?
Buddha214
14
May 26, 2014 03:10 PM
Mr.Cheezil
Jan 20, 2011 09:39 AM
CRXguy_88
May 31, 2010 10:13 PM
CJ407
Jul 17, 2008 01:47 AM
bseriesboosted
Jan 29, 2004 12:55 PM
