need help with brake system
Old May 27, 2010 | 06:35 PM
johnny090881's Avatar
Default need help with brake system
need help removing front rotors from 91 honda accord does anyone know if theres a special tool after removing the center nut like some kind of puller or does anyone have a trick on how to remove stud base
Old May 27, 2010 | 09:09 PM
BatuKing's Avatar
Default Re: need help with brake system
Yes, they do make a hammer puller that attaches to the wheel studs and you can remove it from there.
you still need to remove the nut in the center, then perform the job above.
Old May 28, 2010 | 03:12 AM
hondamark35's Avatar
i've never seen anyone use one of these pullers. it sounds less complicated than pulling the knuckle off and pressing the hub out to get the rotor off. however, if you use this method without first unbolting the hub outer ring from the knuckle, you may end up separating the hub bearing. if that happens you could try to reassemble it but it won't last long so you may as well replace it.
here, this guy used one with success.
if the OP plans on keeping the car for a while and continuing to do his own maintenance check out a rotor-over-hub conversion.
Old May 28, 2010 | 03:24 AM
richi86's Avatar
on mine the rotor just came off with a little pb blaster and a hammer
Old May 28, 2010 | 07:41 AM
cool, thanks for your guy's input, I just pryed it out and the wheel hub came off took a cfew trys but it worked
simonEp3
Sep 3, 2008 04:49 PM
dirtyharryhatch
Aug 6, 2008 03:16 PM
DOHCRAZY
May 26, 2006 06:13 AM
jagged4698
Nov 18, 2004 07:04 PM
slowassR
Apr 30, 2003 01:44 PM
