Air Compressor Problem
Old May 27, 2010 | 03:09 PM
robierv's Avatar
Default Air Compressor Problem
My Air conditioning in my 93 civic is in working condition besides a little glitch. Seems like when I’m accelerating the clutch is slipping. The lag from the compressor seems to go in and out as if the clutch is engaging and disengaging. I played with it for a few blocks and it seemed like it goes off (slips) during Accel. Can anyone confirm that it’s the clutch for sure?
Old May 27, 2010 | 09:17 PM
BatuKing's Avatar
Default Re: Air Compressor Problem
Does it make a noise? could be either a bad compressor or bearing / clutch assy. Check the gap between the two, while applying 12 v to the clutch.
Old May 28, 2010 | 04:29 AM
Former User's Avatar
Also make sure the A/C belt is tight.
Old May 28, 2010 | 07:35 AM
Cynical 1's Avatar
it is normal for the ac clutch to cycle on/off as you drive.
is this your problem, or is it actually slipping and making noise?
CrossCountry
19
Jul 7, 2016 06:03 AM
minimarine09
Jul 2, 2014 06:46 AM
civic=goodgasmileage
Honda Civic (2001 - 2005)
May 25, 2010 09:45 AM
saveacivic
Jun 24, 2008 09:21 PM
