motor revs slowly, timing is good and no CEL
Old May 27, 2010 | 12:58 PM
eghatchfla's Avatar
Default motor revs slowly, timing is good and no CEL
its a b18b1 in a 92 civic hatch.
the motor revs slow and doesnt have the power it normally does.
i need this fixed!
ANY help will be appreciated..
thanks
Old May 27, 2010 | 08:00 PM
tonyhatchetman's Avatar
Default Re: motor revs slowly, timing is good and no CEL
i need this fixed!
thanks
try revving it manually under the hood if it revs fine the cable could be bad,...........and check the catalytic converter (at night run it till it gets warm and then rev it up to about 3000 rpms and look under it at the catty if its glowing orange it could be plugged up )
and too check the air filter .
Old May 27, 2010 | 08:31 PM
BatuKing's Avatar
Check ignition timing? Does it feel like a missfire? need more specific info..
if it was a cat converter you would only notice it under a load. If you can put a vacuum gauge on it and see what the needle says.
Old May 28, 2010 | 12:27 PM
eghatchfla's Avatar
ignition timing is fuly advanced.. thats the only way it will run halfway descent.
and yes it feels like a misfire, brand new plug and wires, and fuel filter
smokey68321
Apr 18, 2010 05:20 PM
QuiksilverH22
12
Sep 6, 2009 09:03 PM
4dek
Jul 6, 2008 10:51 AM
boostedcivichatchbacksi
Sep 21, 2004 11:56 AM
handydandy
Aug 13, 2004 06:06 PM
