accord keeps getting hot
Old Sep 12, 2002 | 05:09 PM
ahc'monracing's Avatar
Default accord keeps getting hot
I need some help as to why my 93 Accord temperature always gets hot while sitting in traffic? the radiator is in good shape and no possible leaks anywhere? Any advise please!! Also, when I start my car, sometimes the ac unit does turn on. Anybody knows why. In order to turn it on, I must turn the car off and start it back up to register the ac. Again, any assistance would be grateful.
Old Sep 12, 2002 | 05:10 PM
Brandon's Avatar
Life is Suffering
Default Re: accord keeps getting hot (ahc'monracing)
Are you sure the fluid level is good?
Old Sep 12, 2002 | 08:20 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 4:17 PM 11/17/2006
Old Sep 12, 2002 | 08:42 PM
95 GaNgStA AcCoRd's Avatar
Default Re: accord keeps getting hot (schlit)
My 5th gen runs got in traffic too, but thats because
1.) my radiator is jacked up
2.) my cooling system is jacked up
3.) I got into an accident
4.) the hose going from the radiator to the engine *I think* is pinched
Old Sep 12, 2002 | 09:54 PM
purpl7duece's Avatar
your cat could be clogged. your radiator might need to be flushed. coulb be a lot of things. flush your radiator first. does the catalytic converter have more than 75,000 miles on it?
Old Sep 12, 2002 | 10:12 PM
the temp goes almost to the top yet no smoke in the engine bay.
what I said about the ac is that sometimes when I turn the ignition, the ac unit isn't working. In order to power it up, I have to turn the car off and start it back up. I'm wondering if a relay could be faulty, I don't know.
Old Sep 12, 2002 | 10:14 PM
Brandon's Avatar
Life is Suffering
Check the fluid levels. There may be a leak in the radiator cap.
Old Sep 12, 2002 | 10:58 PM
H22aInside's Avatar
Default Re: accord keeps getting hot (B the Turbo Pimp)
possible crack in the radiator. can u smell collant burning, it smells kinda like rotten ****. if so then u prob have a minor radiator leak.
just a possibility
Old Sep 12, 2002 | 11:07 PM
Default Re: accord keeps getting hot (H22aInside)
!@#% I guess I gotta cracked radiator ontop of all that other stuff
Old Sep 13, 2002 | 05:27 AM
Stew Pidasso's Avatar
just a possibility
My coolant has always smelled like maple syrup.
Also, check your thermostat.Does it go down if you rev the engine? It may just be the pressure of the water pushing it open a speed but at idle there is not enough pressure to hold it open.This was discussed in another thread recently.
Old Sep 13, 2002 | 06:23 AM
CardDealer's Avatar
Banned
Default Re: accord keeps getting hot (purpl7duece)
Modified by CardDealer at 4:16 PM 11/17/2006
Old Sep 13, 2002 | 06:51 AM
GimpyAccord's Avatar
I'd lean towards thermostat. After a long time those things will crack and allow about - this much water through... if any at all.
Now we're not talking about the electric thermostat, we're talking the mechanical on the back of the block right by the throttle body. all you need is some coolant, a flat head screw driver and a 10mm socket to change it.\
Assuming you dont live way up north (sorry didnt see your location) you might wanna take this opportunity to step down to a 180 degree thermostat.
Old Sep 13, 2002 | 08:55 PM
H22aInside's Avatar
Default Re: accord keeps getting hot (Nitz5785)
what kinda of maple syrup do u buy . lol.
Old Sep 13, 2002 | 10:05 PM
97V6ACCORD's Avatar
I'm pretty sure it's your temperature sensor. I had the same problem before and luckily I was able to pinpoint the problem right away. Try checking that sensor, it's probably not operating anymore.
PEACE! CARPE DIEM!
Old Sep 13, 2002 | 10:06 PM
NXAccordTO4B's Avatar
Hey I had the same problem, it turned out to be a headgasket. Check to see if your water level in your radiator is disappearing, or maybe your water pump. However, mine was a headgasket.
Old Sep 13, 2002 | 11:33 PM
Default Re: accord keeps getting hot (97V6ACCORD)
where can I find the temp sensor? is it reachable by hand?
Old Sep 14, 2002 | 06:31 PM
Ybnorml's Avatar
If you don't get hot while moving and you do while you're still, water isn't circulating, whether it's from it being in your oil, low, the thermostat being stuck or whatever. I've seen defective fans cause that, lack of coolant, and a few other things. I hope that helps.
Old Sep 15, 2002 | 12:03 AM
Default Re: accord keeps getting hot (Ybnorml)
where you start first? the fan does work and I always check the coolant level before a trip. So I'm wondering about water in the oil? Is that what you meant? If so, what does that mean? How can I fix that problem?
Old Sep 15, 2002 | 08:13 AM
Ybnorml's Avatar
Pull your dipstick out and see if it's a milky grey or it's natural color. If it doesn't look like oil there's a chance you have a blown head gasket or cracked head. Along with that usually come some missing in your engine. If neither is the case, I'd carry it to a radiator shop and have it checked out or go it to a shop to have it looked at by someone else who is a mechanic.
Old Sep 15, 2002 | 08:47 AM
Accord94DX's Avatar
STOP. Before you do anything, answer dis question.
DO YOUR FANS WORK?
If "no" then replace the TW sensor on the bottom of your radiator.
If "yes" then read all the posts above....
Old Sep 15, 2002 | 09:28 AM
CardDealer's Avatar
Banned
Default Re: accord keeps getting hot (Me Love You Long Time!!!)
Old Sep 15, 2002 | 09:31 AM
Accord94DX's Avatar
TW sensor is not on the bottom of the radiator...it's either on the thermostat housing or below the distributor. Dont have my book on me so i cant check.
bah! Last one I replaced was on my LXi, that was at the bottom of the radiator.......you get the point.
maddmike24
Jul 31, 2011 08:17 PM
ChevelleSSLS6
Jul 24, 2009 07:37 AM
MarcosMarcusM
May 16, 2009 12:10 PM
mugwump
Jun 17, 2004 12:27 PM
ACCORDianate
Mar 17, 2004 07:08 AM
