$1K; WWJD?
Old May 25, 2010 | 08:17 PM
dippah's Avatar
Default $1K; WWJD?
First let me say I dont drag/street race anymore so I want a reliable build. That being said, im willing to put about a grand towards my/a motor that will last yet be fun.
I have a B18B in my 98 Integra w/ what a buddy tells me is a Type-R trans (it was worked on before I bought the car, I dunno how to tell). The motor needs a rebuild all four cylinders are off, ranging from 135-145 says the compression test. And it needs an Idle Air Control Sensor.
A. Is it worth the (B18B) rebuild for a fun daily driver; what compression?
B. Where can I find a B20Z? cause I cant find the Ish anywhere
C. If were to find a B20Z, would a lightened flywheel do me good or would it just be a waste on the stock motor?
D. What do you think of a B20B compared to LS
Big ups to anyone willing to answer any of these questions for me; Please specify (ABC, etc.)
Old May 25, 2010 | 09:06 PM
jhholloway's Avatar
Default Re: $1K; WWJD?
a. no, new pistons will kill your budge. looking into type r replica if you do though
b. tiger motor/ hmotors i picked mine off craigslist for $200
c. flywheel no good
d. b20 > ls
Old May 25, 2010 | 10:37 PM
dippah's Avatar
e. Anyone ordered from tiger motors? I looked it up BBB rates it as an F for 22 Complaints
f. What factory piston options would I have for the B20B anything better than the regular Z pistons (just saying cause Type-R & GSR's run under $200 and I can pick up a Tiger B20B for $600 = under budget vs. B20Z $850 = getting closer)
Old May 26, 2010 | 05:32 AM
jhholloway's Avatar
google is your friend. NO normal stock piston will work b20...2.0 liters...84mm bore not 81mm.
also remember you CAN'T use the CRV trany. and you are doing an illegal swap it will not BAR.
Old May 26, 2010 | 05:57 AM
dippah's Avatar
Yeah, I figured the B18 Pistons would be too small but was wondering if H-Series would. Anyhow, ive got a B18B setup in my Integra and Type-R trans, as previously mentioned. Didnt know what BAR meant but am familiar with google and took your advice: <i>If the engine came from a same year or newer car, then it can be a legal swap. If not, then no.</i>(b20Z in my 98 Teg) https://honda-tech.com/forums/acura-integra-6/bar-ls-gsr-swap-2522429/. Used the search button to try and find out about MD BAR and came up short. So, since I live in MD which should have much less strict emissions than California, should I be okay? Thanks for the info thus far, keep it coming. Id like to settle on a motor ASAP
Old May 26, 2010 | 06:17 AM
jhholloway's Avatar
i have never heard of swapping h and b stuff. I have looked into it all either. It's kind like emissions or state inspection... another way big brother likes to crap on our fun lol.
Yes you are right about the year thing, but you cannot swap a light truck engine into a car. i was not worried about it.. i still have a b20 in my sol. but in VA everything is illegal. you can't modify a car at all.
Old May 26, 2010 | 06:48 AM
SR20S13's Avatar
well hes not from Cali, so i don't think he has to worry about that, most other states if they have emmissions testing just put you on the sniffer and if you pass, you pass, ooo yeah if you have OBD-II then they check to make sure you don't have any CEL's
Old May 26, 2010 | 06:58 AM
noboostedEGo's Avatar
Not if they're oem pistons. In an ls bottom end with an ls head, 3 different oem pistons would net a mid 11 compression ratio according to http://www.zealautowerks.com/bseries.html
Does the car have bolt-ons already?
I'd just stick with what you already have if you're on a budget. Make sure you've got a decent intake/header/exhaust, toss on a s2/blox im and some crower 403 cams...and a tune.
Old May 26, 2010 | 08:47 AM
dippah's Avatar
This sounds like MD emissions..."Sniffer-pass", lol. Also, in MD we only need to have our cars inspected once when we buy it. Its supposed to be the worst out of most states but mine passed.
Old May 26, 2010 | 10:49 AM
fungus mungus's Avatar
I'd steer clear of Tiger Japanese. Doing a search for them on this forum will be an eye-opener. Go with HMotors...proven time and time again to be the safest place to a motor.
fm
Old May 26, 2010 | 12:54 PM
1.5Slowmatic's Avatar
this place in VA is very good
http://www.japaneseengineimport.com/
what part of MD you from? I'd probably re-build the LS completely that way it has zero miles on it opposed to a motor with 30-50k on it. You cant beat fresh for reliability.
95ludeVTEC
Apr 13, 2010 07:36 PM
GsDAteg
Sep 18, 2007 09:38 PM
Allmtr16
Apr 26, 2006 08:04 PM
Origin
Oct 21, 2005 09:32 AM
V8'suck23
Apr 3, 2003 08:11 AM
