Bad VSS or Stupid move?
Old May 25, 2010 | 05:46 PM
AFAccord's Avatar
Default Bad VSS or Stupid move?
So after a recent motor swap, my speedo started acting finicky. It was fine for the first hundred miles, then it began to skip around, until it finally stopped working completely. The symptoms are exactly that of a bad electrical connection. It randomly comes back to life, and has worked about 50% of the time up until this weekend when it has stopped for good.
I pulled the VSS out yesterday to check its physical condition. I popped the top off of it to check the wiring. The grease inside surrounding the 'wheel' at the top of the shaft where the electric sensor picks up seemed dried up and 'cakey', so I scooped it out and cleaned everything up. Upon reassembly, I repacked that area with the dielectric grease I had used on the connector.
Now that everything is back together and installed with the corrosion cleaned up, the speedo is still dead as a doornail. I'm getting continuitiy to ground from the black wire, battery voltage from the black/yellow wire, and a steady 4.62v from the blue/white signal wire whether driving or sitting still. The service manual calls for 5v or more from the signal wire. I'm not sure how significant that is, but the point is it's not working. Now I'm wondering if that dielectric grease might be preventing the inductive capacity between the sensor pick-up and the wheel. So... bad sensor, or stupid move??
EDIT: VSS is from a Prelude Si, M2S4 tranny. Voltage was read from VSS pigtail while plugged up to the engine harness.
Old May 25, 2010 | 08:03 PM
jordan_rael_420's Avatar
Default Re: Bad VSS or Stupid move?
goto a junk yard and pick up one to see if it is a bad vss
Old May 26, 2010 | 04:05 AM
BlackCatt's Avatar
I had same problem about one year ago. It turned out to be the vss unit itself. First
i found a replacement from a wrecker and then it started to fail as well. I spoke to a
auto electrician and he said that the circuitry within the unit itself fails with age due to
the harsh conditions they endure over nearly two decades. He recommended i get a new
unit from Honda, i did and no problems since. They are also quite affordable new (when i
got mine it was only $15 more than a used unit), so i would recommend first testing with a
known good used vss, and if that works, get a new one. Otherwise it is just a matter of
time until the used one fails.
Old May 26, 2010 | 01:42 PM
AFAccord's Avatar
Cool. I think I've got a couple other VSS's in my garage. They're not the right one for the tranny, but I could always swap it in to test. I'll try that this weekend hopefully.
Old May 26, 2010 | 02:17 PM
Targa250R's Avatar
be professional
Is the Check Engine light on and are you getting a code for the VSS? If so, the problem is in the VSS itself or its wiring circuit.
If the Check Engine light is not on, the problem may likely be a bad speedometer head.
Old May 26, 2010 | 02:33 PM
AFAccord's Avatar
No CEL, no codes. By speedo head are you referring to the gauge assembly?
Old May 27, 2010 | 09:02 AM
jlude90's Avatar
You won't get a failed VSS CEL until a wire has completely broken inside. As of right now its just not reading the input from the unit in the transmission, but voltage is still going in an out from/to the ECU, so it knows its connected.
I've had this same issue before being the VSS with no CEL.
Old May 27, 2010 | 03:14 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
What car is this in? The cluster has a tendency to go bad on 91-96 hondas as well. So if a new VSS doesnt help you may need a new cluster.
Old May 27, 2010 | 07:06 PM
jlude90's Avatar
Not really notorious on preludes, generally is the sensor.
Old May 27, 2010 | 07:30 PM
AFAccord's Avatar
Car is a 2000 Accord.
I know the issue is either faulty wiring/connection or intermittent speed sensor. When my speedo would drop out (often during hard acceleration), my launch control's rev limiter would activate because the ECU saw '0 mph' from the sensor. From what I can find in the service manual, the signal wire literally branches out to the ECU, speedo, and cruise control unit, so evidently they are all seeing the loss of signal.
I'll be going up to my garage tomorrow. I don't think I have another H23 VSS, but I might have a couple others to try out. We'll see...
QUESTION: Since all the FWD F/H series trannys are interchangeable and the VSS is only reading off the differential ring gear, can I use any F/H series VSS with the 4.266 final drive?
Old May 28, 2010 | 10:15 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Yes . They are the same part.
Old May 28, 2010 | 05:05 PM
AFAccord's Avatar
Well, got 'home' today and dug up my stock VSS. Hooked it up to the drill, connected it to the plug and turned the ignition on. Spun it up, and nothing happened. Speedo didn't budge and ECU didn't register anything. Reconnected the original VSS and tested it out with the same result.
Still seeing battery voltage at the sensor black and black/yellow wires, continuity to ground from the black wire, and 4.68v from the blue/wht sensor wire. Not sure what in the hell is going on here. I'm almost to the point of cutting off the plug and routing my own wires from the VSS to see what I get. Any more suggestions?
Old May 28, 2010 | 11:04 PM
Davisaudio20's Avatar
possibly a bad ground. check all the wires. had the same issue on a bb.
Old May 29, 2010 | 07:37 AM
AFAccord's Avatar
I'm headed down today to get this thing done...
My plan is to disconnect all termination points and attempt to track down any shorts or shunts in the circuitry, double check all grounds, and rerun any wires that could be causing the issue.
Old May 29, 2010 | 08:28 PM
BlackCatt's Avatar
GL, hope that fixes the problem. Electrical issues
can be f*%king annoying to sort out some times.
Old May 30, 2010 | 10:50 AM
B16CRXT's Avatar
Jason, try splicing a wire from the signal near the plug straight to the speedo and see if the signal comes through.
Old May 30, 2010 | 02:42 PM
AFAccord's Avatar
Good news! It's fixed!
Continuity tested good from the sensor's connector to the gauge cluster harness, so the fault had to be in the connection. I pulled the plug apart, and the metal terminals literally fell apart in my hands. I pulled three terminals from my unused EGR plug to replace them.
Crimped and shrink-wrapped...
I almost forgot how well this car pulls at full throttle. I'm a happy man!
Old May 30, 2010 | 07:05 PM
BlackCatt's Avatar
^ good to hear.
jdmef69
May 5, 2012 08:19 AM
AFAccord
May 26, 2010 02:00 PM
ohsnapzafingcu
Jan 1, 2009 10:06 PM
aznryd3r
Nov 24, 2006 10:05 AM
AdamITR
Apr 16, 2003 02:18 PM
