need help
does it have the HF engine harness on it?
on the HF harness, the white wire at pin #2 is for the igniter which is in the distributor - the white wire should be in the round 7-wire distributor connector - it is in the middle row of 4, on the end opposite the empty pin
on the HF harness, the yellow wire at pin #3 is for the EGR lift valve - the EGR lift valve is located on the passenger side end of the intake manifold - kind of next to the distributor - has a 3-wire connector - the wire colors are yellow with white stripe, green with white stripe and solid yellow, which is the wire going to pin #3 in the C313 connector at the driver's side
this is the distributor connector wire locations for both HF and Si
turbob18si
Apr 2, 2013 09:09 AM
90crxdriver
Jul 6, 2008 11:59 AM
1 Fly SI
19
Nov 15, 2006 09:14 AM
