Rigid strut tower bar won't fit???
Old May 25, 2010 | 03:59 PM
Steady R's Avatar
Default Rigid strut tower bar won't fit???
I have a Rigid front strut tower bar. the Triangulated one that bolts to the firewall but i can't mount it up. the bar hits the brake mastercylinder. This bar was previously installed in my EG with ITR master and booster and it just barely fit.
Is there a smaller mastercylinder reservouir available. i know that there's some way to mount this.as i seen this bar on ITR's before
Old May 25, 2010 | 04:02 PM
jdmspoonitr's Avatar
Default Re: Rigid strut tower bar won't fit???
I know some people used to dremel very lightly on the reservoir cap. Obviously just a mm or two, don't go all the way through and be careful. Or you could fab a spacer for the shock tower bolts so it sits a bit higher.
Old May 25, 2010 | 09:24 PM
94rs-turbo's Avatar
proper way for make it work is to flip the MC res around.
only one bolt on the bottom, take it out reservoir pulls up(make sure you empty it first!!) turn it around and put it back in place, put the bolt back in and bleed your brakes, bolt your bar on and hit the turns GL hope that helped
kinda see in the pic what I mean
Old May 26, 2010 | 06:05 AM
LankorDie's Avatar
Loved
Community Favorite
This is man is correct.
Old May 26, 2010 | 06:11 PM
Steady R's Avatar
Thanks for the replies. I should have searched before i posted.
I will follow up with some pics when i get er done
italian_virus
Apr 29, 2010 08:09 AM
JMelt4
42
Feb 23, 2007 05:53 AM
erasable180
Nov 24, 2005 06:17 PM
SIC_WIT_IT
Feb 6, 2005 01:02 PM
stareatsun
Feb 18, 2004 06:46 AM
