new o2 sensor - running like poo
Old May 25, 2010 | 02:51 PM
scoob8000's Avatar
Default new o2 sensor - running like poo
94 1.5l D15B7 Civic
So I just changed my o2 in hopes of passing emissions testing.
Since the change the car has been running like crap. Bogging down in lower RPM's until 2500 or so when it takes off.
It's actually acting like the timing is off, but I just checked valve and spark time. It's fine.
Does the ECU need to be reset or is there a learning period after changing the o2?
Old May 25, 2010 | 02:56 PM
jdmh22eg2's Avatar
Default Re: new o2 sensor - running like poo
yea pull main ecu fuse and (+) term for 30 sec main fuse is under hood should be back left corner 15a
Old May 25, 2010 | 05:50 PM
96DelSol's Avatar
yes reset the ecu for atleast ten seconds.
Old May 25, 2010 | 07:39 PM
TheJGB3's Avatar
If you bought a Bosch O2 sensor then that is your problem (they're crap).
The OEM for Honda's O2 sensors is NTK (NGK) and they are usually under $60 shipped
Old May 26, 2010 | 03:01 AM
scoob8000's Avatar
Will try resetting the ecu and will report back.
Is pulling the fuse sufficient, or does the battery really need to be disconnected to reset the ecu (and my head unit :D )
TheKGB3,
Nope I go to lengths to stay away from Bosch products. (Been burnt by faulty o2, plugs, and fuel pumps)
Old May 26, 2010 | 03:23 AM
BryanM.'s Avatar
Resident Gearhead
I thought Denso made the OE 02 sensors?
Old May 26, 2010 | 02:07 PM
TheJGB3's Avatar
Nope, NTK is the O2 sensor division for NGK, and they are the OEM supplier to Honda for O2 sensors.
Old May 26, 2010 | 04:39 PM
98civdx's Avatar
Master Detailer
I have a bosoch o2 and its fine, so i would call them junk unless you have proof.
Old May 29, 2010 | 01:52 PM
scoob8000's Avatar
Well just to update..
I've put about 200 miles on it since resetting the ECU.
It does run a little bit better. BUT. My last fillup I only got 25mpg. Mostly highway.
Could a new o2 be that bad, but still not throw a code?
Old May 29, 2010 | 04:55 PM
98civdx's Avatar
Master Detailer
^^Thats about whay i get, although i got 28 last tank and 25 this one.
Old May 30, 2010 | 04:56 AM
scoob8000's Avatar
FWIW, I was getting 32-38 before the new o2. (Threads are ruined on the old one so no I can't put it back in.) :/
Old May 30, 2010 | 02:32 PM
98civdx's Avatar
Master Detailer
Hmm well maybe thats your issue, the only thing that changed with mine was the octain #.
93 on the 28 and 87 for 25, both were from shell.
lilshady6796
34
Mar 27, 2009 07:49 PM
HONDA RR
Sep 16, 2005 03:53 PM
94gsr_vtc
Oct 24, 2004 01:06 AM
Rywire
Jan 4, 2003 09:53 PM
