00 si...Idle problem
Old Sep 12, 2002 | 04:16 PM
HybridCoupe's Avatar
Default 00 si...Idle problem
My 00 SI is fine at idle until given gas then idle will jump from 1100-1900 constantly and will not hold an idle at all...any sugestions?
Old Sep 12, 2002 | 04:25 PM
Nameless RB26's Avatar
Default Re: 00 si...Idle problem (HybridCoupe)
reset your ecu.
pull off neg. battery wire for a couple minutes, reconnect and let idle for a while.
may not work, but it doesn't hurt to try
Old Sep 12, 2002 | 05:03 PM
VTEC-DA's Avatar
Default Re: 00 si...Idle problem (Nameless)
Check vacuum lines for leaks. Are you throwing any codes (CEL)? If so, which ones?
Old Sep 12, 2002 | 05:17 PM
2000blacksi's Avatar
New User
Default Re: 00 si...Idle problem (CivicthatsBlack)
sounds like a vacuum leak to me
actually its throwing CEL 10....
See-Tee-R
Nov 15, 2010 07:14 PM
Slammed_am
Sep 15, 2008 01:11 PM
paowa
Jan 24, 2007 08:30 PM
dsadas89das78934
13
Mar 14, 2004 11:30 AM
quik2kSi
Nov 12, 2003 08:45 PM
