Half shaft prob
Old May 25, 2010 | 12:05 PM
Hondatherdm's Avatar
Default Half shaft prob
So i have b16a2, trying to put gsr half shaft and heres what i get(look at a pic)---Name:  half shaft.jpg
Size:  33.1 KB and i took my friend 94 tegra shaft looks exactly like mine, which means it wont fit
Old May 25, 2010 | 03:54 PM
Default Re: Half shaft prob
anyone?
Old May 25, 2010 | 04:50 PM
300whpej's Avatar
turn it more towards the block and bolt it in
Old May 25, 2010 | 06:27 PM
I know but i can turn it over thats as far as it goes
Old May 25, 2010 | 06:41 PM
DOHCterJEREMYb's Avatar
try getting the half shaft for a b16?
Old May 25, 2010 | 08:58 PM
D16SiHatch's Avatar
is it possible the intermediate shaft came off an automatic transmission? if so, it won't work.
Old May 25, 2010 | 10:47 PM
honda_luvr_2000's Avatar
He is exactly right... I ran into the same problem. Visually the A/T & M/T look almost identical. 94-01 Integra LS,GS,RS,GS-R,Type R M/T's, 94-97 Del Sol VTEC (DOHC), and 99-00 Civic Si all have the same intermediate (half/mid/jack) shaft (even part number is the same). Check the part number stamped on the edge of the bearing carrier.
SR3-J8 = A/T
SR3-J0 = M/T
edit:
If you look at the picture you posted, you can see the part number I'm talking about just to the right of the bottom left bolt hole. Unfortunately, I can't make out all of it so you'll have to check it yourself.
Old May 26, 2010 | 10:56 AM
Its sr3-j8, which according to you is from auto... ill get another one with j0 see what happeneds
Old May 26, 2010 | 11:07 AM
raidacaipo's Avatar
automatic half shaft like everyone else stated
Old May 26, 2010 | 01:10 PM
tlarimer's Avatar
+1 for it being auto intermediate shaft. I have an auto one in the basement that came off the auto B16A swap I bought. I used the intermediate shaft from a 95 integra LS, works like a charm.
Old May 26, 2010 | 07:55 PM
Thanks everyone
Chenzo
Sep 30, 2014 04:13 PM
91(si)hatchey
Aug 16, 2009 06:36 PM
mixmastermatt
May 13, 2007 07:43 AM
CTL
Mar 8, 2004 07:11 AM
