fuel injector problem
i just did a wire tuck and in the process tried to fix the half a$$ odb1 conversion
everything is obd2 except the fuel injectors
after tucking my car ran funny idle wasnt right and backfired a little bit
its throwing code 16 fuel injectors
anyone have an idea of what is wrong?
would i just be better to wire for obd1 injectors
If his injectors are in fact obd0 then his resistor box isn't hooked up. It's laying on the valve cover
I just kept my resistor box and tucked that. It was really easy.
yes the injectors are obd0 and the resistor box is laying there but i pulled it back out to make sure it was connected
i did the tuck them fished alot of wires back out to source the problem
the car starts right up it seems like its getting too much fuel.. is this possible? i can smell it bad and theres no leaks
that seems like the constant spraying is an issue.. cant find whats causing it though
is there a good diagram on how these should be wired using the resister box? i cant find one anywhere
was the car not factory mpfi?
probably not finding much on it because it's very simple to wire up. on the box one wire receives 12 volts and the other 4 supply power to each injector. the 4 grounds on the injectors go back to the ecu and is what tells the injectors to spray
ok well the car has been converted to obd1
- has obd0-obd1 conversion harness some of the wires from the conv. harness go to the fuel injectors
i cant tell where the original wires go to for the mpfi swap since everything has been changed
ok so i did some researching, in order for the injectors to spray the curcuit must be completed (ecu grounding out each injector) so i must have a grounding problem b/c im constanly squirting fuel.
my ? is are the pinout for obd1 the same as obd0? for the fuel injectors?
has anyone ever had this problem b4
e jay one
Aug 6, 2005 02:48 PM
