em1 oil issues!
Old May 25, 2010 | 07:38 AM
ultraplayer26's Avatar
Default em1 oil issues!
is it normal for a em1 to burn a quart of oil every month..i have checked everything in the car and no leaks anywhere..i use royal purple 10-30..?
Old May 25, 2010 | 07:56 AM
crxboy909's Avatar
Default Re: em1 oil issues!
no. have u ever done a tune up on it?
Old May 25, 2010 | 08:27 AM
dale m.'s Avatar
could be your valve seals or rings mines doing the same thing so im building it next month
Old May 25, 2010 | 01:36 PM
blowededup's Avatar
How many miles are on the motor?
Old May 25, 2010 | 01:44 PM
Deetz's Avatar
Crazy Honda Guy
The B16A in that car is 10 years old now. A combination of some wear on the piston rings, as well as the valve seals start to dry out over time are what lead to burning oil.
It is not uncommon for it to use oil month to month. Depending on how you drive it will affect consumption also.
Old May 25, 2010 | 02:21 PM
well i changed the oil the other day,its only got 73,000 miles,but i am running e85 on it...could it be cause of that..i also drive it hard..3 out of seven days a week..
Old May 26, 2010 | 08:58 PM
dale m.'s Avatar
i have 110k miles on mine
Old May 26, 2010 | 10:07 PM
Sutterlude's Avatar
CONGRATS!!!!
the e85 could have some effect on the rings
Old May 26, 2010 | 10:39 PM
D16SiHatch's Avatar
i sure hope you have it tuned for e85
Old May 26, 2010 | 10:49 PM
EgHatchB20's Avatar
Sounds like the rings are bad
Old May 26, 2010 | 11:18 PM
chewyv's Avatar
pm4nudes
i thought e85 will burn the **** outta everything if used daily?
Old May 26, 2010 | 11:39 PM
D16SiHatch's Avatar
it effects some hoses and parts differently yes. the main concern is if you run it in a vehicle it was not intended to be in, the engine will be running lean as fawk!
Old May 27, 2010 | 08:42 AM
mines is tuned on e85 new fuel rail filter pump and new gas tank,and injectors along with fuel lines right before i dynoed....yes you do have to change the main fuel line from filter to fuel rail...i got mines made at a hydraulic shop with heavy duty fittings...
duckiexd
Jun 14, 2011 06:50 PM
joss731
Sep 15, 2010 08:50 AM
Jorsher
Sep 7, 2006 06:05 PM
Si Erik
Nov 18, 2003 06:46 PM
Wazup
May 1, 2003 06:51 PM
