Swapping rear LCAs DIY?
Old May 25, 2010 | 06:16 AM
FSUseminoleEM1's Avatar
Default Swapping rear LCAs DIY?
Hey -
Does anybody have a link for a how-to on removing/installing new rear LCAs ('96 - '00 civics)?
Thanks.
Old May 25, 2010 | 06:30 AM
acake em1's Avatar
Colonel Cake Mix
Default Re: Swapping rear LCAs DIY?
you dont need a link man its simple... remove the 3 bolts on the old lca... my advice is to get new bolts since they old ones have tendency of rounding off or breaking off.
then you put the new lcas on and put the 3 bolts in.
if you have a sway bar u need to remove that nut or bolt as well
Old May 25, 2010 | 06:35 AM
VTECROAR96typeR's Avatar
This.. and chances are that you will break the old bolts.
Old May 25, 2010 | 02:10 PM
Corksil's Avatar
simple stuff, you need no guides for this kinda thing. Ive done it many times, easy easy. look at them and you'll see which bolts you have to remove.
like someone said.. if you have a sway bar, there will be an extra bolt.
Old May 25, 2010 | 02:39 PM
EL Vap133's Avatar
Remember to soak the bolts with WD-40 and use jack stands.
Old May 25, 2010 | 02:42 PM
Deetz's Avatar
Crazy Honda Guy
Yup, that helps. I have found that "liquid wrench" works even better than wd40
Old May 26, 2010 | 07:41 AM
EL Vap133's Avatar
Oh well there you go, I never heard of it but if it works go for it.
Old May 26, 2010 | 08:39 AM
thanks guys...no anti-sway bar yet, but soon.
Old May 26, 2010 | 09:19 AM
vansxskater's Avatar
I would pick up a can of pb buster and soak all the bolts for a day. Then the next day i would swap out the lca's. If you break those bolts you'll be pissed of because they are a b**ch to get out. Plus they are 8 bucks a piece straight from honda.
HotCheetos
10
Dec 11, 2010 09:07 PM
IntegraGSR1999
Suspension & Brakes
May 12, 2010 12:18 PM
charliemopps24
Apr 30, 2007 09:12 AM
HKSuperSi
Feb 13, 2007 08:38 PM
whttyper1998
Feb 5, 2002 04:30 AM
