Built B20V NA LongBlock
I have a b20V set up I'm looking to part out. Heres the set up, car put down alittle over 240hp. 210 across all cylinders so its healthy with about 40K miles. If you want it complete and running with a shell check my other listing of it with the car. Looking to get $2800 OBO for the longblock. Motor is still in the car, you can come check it out. I'll need a $200 nonrefundable deposite to pull it out.
b20 block
golden eagle 95mm stroker crank
eagle rods
84mm cp stroker pistons 11.5:1
cometic head gasket
golden eagle lsvtec line kit and sandwich plate
gsr head pnp (Dan Paremore Racing)
skunk2 intake mani pnp (Dan Paremore Racing)
skunk2 70mm throttle body
skunk 2 stage 2 cams
skunk2 dual valve springs and retainers
aem cam gears
750 rc injectors
aem fuel rail
hondata intake mani gasket
endyne breather kit
JDM blue valve cover
JDM ITR crank pulley
b20 block
eagle rods
cometic head gasket
aem cam gears
750 rc injectors
aem fuel rail
endyne breather kit
Chee_dog
May 25, 2011 10:48 PM
